Incorrect Timezone on Dashboard  [SOLVED]
LastSavingGrace
Post by LastSavingGrace »
Hi Alex,
I have set the timezone to Europe/London in the Keyhelp config and if I check the server using 'date' it is the correct UK timezone, but on the Keyhelp dashboard it says:
XX:XX:XX - July 24, 2022 (America/Los_Angeles)
The time is always correct, but the timezone wrong. Bug maybe?
select name from me;
Re: Incorrect Timezone on Dashboard
LastSavingGrace wrote: Sun 24. Jul 2022, 05:51 Hi Alex,
Probably your OS PHP timezone is still wrong. The timezone is defined in many files.
These are the steps, that I do, if I need to change the timezone. I use Ubuntu.
# Check the OS timezone
ls -l /etc/localtime
# Set the OS timezone
timedatectl set-timezone Europe/Berlin
# Set the OS PHP timezone
vim /etc/php/7.4/mods-available/timezone.ini
vim /etc/php/7.4/cli/conf.d/30-timezone.ini
# Set the Keyhelp timezone for every installed PHP Version
vim /opt/keyhelp/php/8.0/etc/conf.d/30-timezone.ini
vim /opt/keyhelp/php/8.1/etc/conf.d/30-timezone.ini
I hope this helps.
Viele Grüße, Christian
BasHeijermans
Post by BasHeijermans »
What does this tell you?
timedatectl
Should show this, as mine is set for Brussels.
Local time: zo 2022-07-24 16:20:04 CEST
Universal time: zo 2022-07-24 14:20:04 UTC
RTC time: zo 2022-07-24 14:20:04
Time zone: Europe/Brussels (CEST, +0200)
System clock synchronized: yes
NTP service: n/a
RTC in local TZ: no
Maybe your machine runs different and hasn't been set correctly.
Sometimes all it takes is a reboot after a setting change, you never know.
Greetings Bas.
Re: Incorrect Timezone on Dashboard  [SOLVED]
Have you updated "Configuration -> System Time"?
This should normally takes care of updating the timezone in all relevant files.
... it updates:
# The system default PHP interpreter:
/etc/php/*/mods-available/timezone.ini
# All optional PHP interpreter
/opt/keyhelp/php/*/etc/conf.d/*timezone.ini
... and utilize the command:
... and restarts the PHP-FPM services.
