Dienst-/Portüberwachung der Port http 80 Offline  [GELÖST]
Ruffaelo
Post by Ruffaelo »
Problem nur im Keyhelp zu sehen
(z.B. Ubuntu 20.04)
Betriebssystem Debian 11.4 (64-bit)
keine
(z.B. 22.0 - Build 2366)
KeyHelp 22.1.1 (Build 2691)
Dienst-/Portüberwachung ist der Port http 80 Offline
Firewall:
Position Name Aktion Ports Quellen
1 SSH Zulassen TCP: 22 —
2 DNS Zulassen TCP: 53 UDP: 53 —
3 HTTP / HTTPS Zulassen TCP: 80, 443 —
4 POP3 Verweigern TCP: 110, 995 —
5 IMAP Zulassen TCP: 143, 993 —
6 SMTP Zulassen TCP: 25, 465, 587 —
7 MariaDB / MySQL Verweigern TCP: 3306 —
8 FTP + ProFTPD Passive Ports Zulassen TCP: 20, 21, 30000-30500 —
Ping Zulassen
Standardrichtlinie Verweigern
http 80 Online
Re: Dienst-/Portüberwachung der Port http 80 Offline
Was sagt
apache2ctl -S
Was
netstat -luntep|grep 80
Ruffaelo
Post by Ruffaelo »
24unix wrote: Thu 4. Aug 2022, 12:10 Was sagt
apache2ctl -S
Was
......:~# apache2ctl -S
AH00548: NameVirtualHost has no effect and will be removed in the next release /etc/apache2/ports.conf:12
VirtualHost configuration:
*:443 is a NameVirtualHost
default server... (/etc/apache2/keyhelp/keyhelp.conf:20)
port 443 namevhost ... (/etc/apache2/keyhelp/keyhelp.conf:20)
port 443 namevhost ...(/etc/apache2/keyhelp/vhosts/rn.conf:14)
port 443 namevhost ... (/etc/apache2/keyhelp/vhosts/rn.conf:58)
port 443 namevhost ... (/etc/apache2/keyhelp/vhosts/rn.conf:102)
port 443 namevhost ... (/etc/apache2/keyhelp/vhosts/rn.conf:147)
port 443 namevhost webmail (/etc/apache2/keyhelp/webmail.conf:11)
wild alias webmail.*
port 443 namevhost ... (/etc/apache2/keyhelp/subdomain_catch_all.conf:1)
wild alias *...
port 443 namevhost ...t (/etc/apache2/keyhelp/keyhelp.conf:168)
wild alias *....
*:80 is a NameVirtualHost
default server ... (/etc/apache2/keyhelp/keyhelp.conf:143)
port 80 namevhost ... (/etc/apache2/keyhelp/keyhelp.conf:143)
port 80 namevhost ... (/etc/apache2/keyhelp/vhosts/rn.conf:51)
port 80 namevhost ... (/etc/apache2/keyhelp/vhosts/rn.conf:95)
port 80 namevhost ... (/etc/apache2/keyhelp/vhosts/rn.conf:139)
port 80 namevhost ... (/etc/apache2/keyhelp/vhosts/rn.conf:157)
port 80 namevhost webmail (/etc/apache2/keyhelp/webmail.conf:5)
port 80 namevhost autoconfig (/etc/apache2/keyhelp/autoconfig.conf:5)
wild alias autoconfig.*
wild alias autodiscover.*
wild alias autoconfig-apple.*
port 80 namevhost ... (/etc/apache2/keyhelp/subdomain_catch_all.conf:6)
wild alias *....
port 80 namevhost ... (/etc/apache2/keyhelp/keyhelp.conf:178)
wild alias *....
ServerRoot: "/etc/apache2"
Main DocumentRoot: "/var/www/html"
Main ErrorLog: "/var/log/apache2/error.log"
Mutex fcgid-pipe: using_defaults
Mutex authdigest-opaque: using_defaults
Mutex watchdog-callback: using_defaults
Mutex rewrite-map: using_defaults
Mutex ssl-stapling-refresh: using_defaults
Mutex authdigest-client: using_defaults
Mutex fcgid-proctbl: using_defaults
Mutex ssl-stapling: using_defaults
Mutex proxy: using_defaults
Mutex ssl-cache: using_defaults
Mutex default: dir="/var/run/apache2/" mechanism=default
PidFile: "/var/run/apache2/apache2.pid"
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
Define: ENABLE_USR_LIB_CGI_BIN
User: name="www-data" id=33
Group: name="www-data" id=33
-bash: netstat: Kommando nicht gefunden
OK, der Apache lauscht wohl auf Port 80, würde das netstat dann nur betätigen, netstat ist im Paket net-tools.
Aber wenn der Dienst läuft, die Anzeige aber nicht passt musst Du wohl auf jemanden warten, der den Code von KH kennt, ich weiß nicht, wie die Angaben ermittelt werden.
Ruffaelo
Post by Ruffaelo »
24unix wrote: Thu 4. Aug 2022, 12:39 OK, der Apache lauscht wohl auf Port 80, würde das netstat dann nur betätigen, netstat ist im Paket net-tools.
......:~# netstat -luntep|grep 80
tcp 0 0 0.0.0.0:4190 0.0.0.0:* LISTEN 0 12680 590/dovecot
tcp 0 0 IPV4....:80 0.0.0.0:* LISTEN 0 11905 683/apache2
tcp6 0 0 IPV6...:::8080 :::* LISTEN 0 11907 683/apache2
tcp6 0 0 ...:53 :::* LISTEN 106 11867 593/named
tcp6 0 0 ...:53 :::* LISTEN 106 11868 593/named
udp6 0 0 ...:53 :::* 106 11858 593/named
udp6 0 0 ...:53 :::* 106 11866 593/named
Welchen Browser verwendest du?
Ruffaelo
Post by Ruffaelo »
Tobi wrote: Thu 4. Aug 2022, 12:53 Welchen Browser verwendest du?
Microsoft Edge mit dem Browser hat es nichts zu tun ich habe andere Server auch mit keyhelp da ist das Problem nicht und die sind 1zu1 konfiguriert
Was sagt folgender Befehl?
php -r "var_dump(fsockopen('127.0.0.1', 80));"
Was für Änderungen wurden an der Serverkonfiguration vorgenommen?
Ruffaelo
Post by Ruffaelo »
Alexander wrote: Thu 4. Aug 2022, 14:12 Hallo,
PHP Warning: fsockopen(): unable to connect to 127.0.0.1:80 (Connection refused) in Command line code on line 1
bool(false)
Am server wurden bis dato keine änderungen vorgenommen auser ipv6 static und ipv4 Static in der /etc/network/interfaces
Re: Dienst-/Portüberwachung der Port http 80 Offline  [GELÖST]
Über den genannten Befehl (fsockopen()) wird dies auch in KeyHelp ermittelt. Die Ursache, warum die Verbindung abgelehnt wird, liegt irgendwo in deiner speziellen Serverkonfiguration. Auf einem jungfräulichen System installiert mit blankem minimal System funktioniert die Anweisung.
