Error 500 htaccess  [SOLVED]
PuntonetSvb
Error 500 htaccess
Post by PuntonetSvb »
Tengo el siguiente htacces
Options All -Indexes
Options +FollowSymLinks
RewriteEngine on
RewriteRule seccion-(.*)-(.*)\.htm$ seccion.php?sec=$1&id=$2
RewriteRule otras-(.*)\.htm$ otras.php?id=$1
RewriteRule ver-(.*)-(.*)\.htm$ vercliente.php?nombre=$1&id=$2
RewriteRule enviarmensaje-(.*)-(.*)\.htm$ enviarmensaje.php?nombre=$1&id=$2
RewriteRule enviaroferta-(.*)-(.*)\.htm$ enviaroferta.php?nombre=$1&id=$2
RewriteRule veroferta-(.*)\.htm$ veroferta.php?idoferta=$1
RewriteRule verquehacer-(.*)\.htm$ verquehacer.php?id=$1
RewriteRule verrutamotor-(.*)\.htm$ verrutamotor.php?id=$1
RewriteRule verrutapie-(.*)\.htm$ verrutapie.php?id=$1
RewriteRule verquever-(.*)-(.*)\.html$ verquever.php?n=$1&id=$2
RewriteRule fiesta-(.*)-(.*)\.html$ fiesta.php?nombre=$1&fiesta=$2
y me tira el siguiente error:
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator at webmaster@domain.tld to inform them of the time this error occurred, and the actions you performed just before this error.
More information about this error may be available in the server error log.
Al mirar el log veo lo siguiente:
/home/users/usuario/www/.htaccess: Option FollowSymLinks not allowed here, referer: https://domain.tld/
Estaba funcionando perfectamente en i-mscp hasta ayer.
Mod edit: Added code tags
Re: Error 500 htaccess
You need to supply the contents of
/home/users/usuario/logs/error.log
I guess you speak Spanish, could you provide a description in English?
You might try to use "SymlinksIfOwnerMatch" instead of "FollowSymLinks". The latter is disallowed by default in Keyhelp because of security reasons. So using it in .htaccess will throw an Internal Server Error/Error 500.
PuntonetSvb
My error.log file
[Sat Sep 10 10:00:34.335553 2022] [core:alert] [pid 305573:tid 140350662403840] [client 91.126.41.116:65270] /home/users/sajanansa/www/.htaccess: Option All not allowed here
[Sat Sep 10 10:00:35.772396 2022] [core:alert] [pid 305573:tid 140350662403840] [client 91.126.41.116:65270] /home/users/sajanansa/www/.htaccess: Option All not allowed here
MY HTACCESS MODIFIED
Options +SymlinksIfOwnerMatch
RewriteEngine on
RewriteBase /
But is the same error
Re: My error.log file
PuntonetSvb wrote: Sat 10. Sep 2022, 12:01 [Sat Sep 10 10:00:34.335553 2022] [core:alert] [pid 305573:tid 140350662403840] [client 91.126.41.116:65270] /home/users/sajanansa/www/.htaccess: Option All not allowed here
You still have Option All in the htaccess.
PuntonetSvb
If I remove the line
Options All-Indexes
It doesn't give me the 500 error, but it doesn't apply the rewrite rules below either.
PuntonetSvb wrote: Sat 10. Sep 2022, 12:20 If I remove the line
Options All-Indexes
I just checked a phpBB running on KeyHelp, rewrite is working, no Options are set.
Did you enable mod_rewrite?
Here it is:
# apache2ctl -M|grep rewrite
 rewrite_module (shared)
else:
a2enmod rewrite
PuntonetSvb
I do it but the error is the same
whit this htaccess
RewriteEngine on
error 500
with this htaccess
RewriteEngine on
Not error 500 but error 404 when rewrite
You have not a single rewrite condition.
PuntonetSvb
Re: Error 500 htaccess  [SOLVED]
I have tested it with
.htaccess
Options +SymLinksIfOwnerMatch
RewriteEngine on
Than created a seccion.php file with the content
<?php
echo "This is seccion.php\n\n";
var_dump($_SERVER);
Than called http://mydomain.com/seccion-11-22.htm
And correctly received this (see QUERY_STRING for example):
This is seccion.php
array(40) {
  ["TEMP"]=>
  string(21) "/home/users/test/tmp/"
  ["TMPDIR"]=>
  ["TMP"]=>
  ["USER"]=>
  string(4) "test"
  ["HOME"]=>
  string(17) "/home/users/test/"
  ["SCRIPT_NAME"]=>
  string(12) "/seccion.php"
  ["REQUEST_URI"]=>
  string(18) "/seccion-11-22.htm"
  ["QUERY_STRING"]=>
  string(12) "sec=11&id=22"
  ["REQUEST_METHOD"]=>
  string(3) "GET"
  ["SERVER_PROTOCOL"]=>
  string(8) "HTTP/1.1"
  ["GATEWAY_INTERFACE"]=>
  string(7) "CGI/1.1"
  ["REDIRECT_QUERY_STRING"]=>
  ["REDIRECT_URL"]=>
  ["REMOTE_PORT"]=>
  string(5) "47988"
  ["SCRIPT_FILENAME"]=>
  string(32) "/home/users/test/www/seccion.php"
  ["SERVER_ADMIN"]=>
  string(34) "..."
  ["CONTEXT_DOCUMENT_ROOT"]=>
  string(21) "/home/users/test/www/"
  ["CONTEXT_PREFIX"]=>
  string(0) ""
  ["REQUEST_SCHEME"]=>
  string(4) "http"
  ["DOCUMENT_ROOT"]=>
  ["REMOTE_ADDR"]=>
  string(12) "..."
  ["SERVER_PORT"]=>
  string(2) "80"
  ["SERVER_ADDR"]=>
  string(12) "..."
  ["SERVER_NAME"]=>
  string(24) "..."
  ["SERVER_SOFTWARE"]=>
  string(6) "Apache"
  ["SERVER_SIGNATURE"]=>
  string(0) ""
  ["PATH"]=>
  string(70) "/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin"
  ["HTTP_ACCEPT_LANGUAGE"]=>
  string(45) "de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7,und;q=0.6"
  ["HTTP_ACCEPT_ENCODING"]=>
  string(13) "gzip, deflate"
  ["HTTP_ACCEPT"]=>
  string(135) "text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"
  ["HTTP_USER_AGENT"]=>
  string(101) "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
  ["HTTP_UPGRADE_INSECURE_REQUESTS"]=>
  string(1) "1"
  ["HTTP_CACHE_CONTROL"]=>
  string(9) "max-age=0"
  ["HTTP_CONNECTION"]=>
  string(10) "keep-alive"
  ["HTTP_HOST"]=>
  string(24) "..."
  ["REDIRECT_STATUS"]=>
  string(3) "200"
  ["FCGI_ROLE"]=>
  string(9) "RESPONDER"
  ["PHP_SELF"]=>
  ["REQUEST_TIME_FLOAT"]=>
  float(1662982549.497864)
  ["REQUEST_TIME"]=>
  int(1662982549)
So everything works as expected.
If it does not on your server, there maybe is something which interfere this process.
Default KeyHelp configurations are fine as you can see above and therefor this is not related to KeyHelp.
PuntonetSvb
I generate an htaccess from this website, to test
https://www.generateit.net/mod-rewrite/index.php
and it generates the following code:
RewriteEngine on
RewriteRule ver-(.*)\.htm$ page.php?id=$1
I add the line that you indicated before
and the result is the same, if I write: midominio.com/pagina=closures it works correctly, but if I call the web: midominio.com/ver-closures.htm, I get a 404
2022-10-10 13:57:58 xx.xx.xx.xx 404 GET /view-enclosures.html HTTP/2.0
Could someone help me to generate a working htaccess in keyhelp with which I can do a modrewrite of:
see-idpage.htm and go to page.php?id=idpage
The "page.php" file exists in the same directory?
This is just a typo (?):
or
vs
PuntonetSvb
the same way, 404 error
404 GET /ver-cerramientos.html HTTP/2.0
PuntonetSvb wrote: Mon 10. Oct 2022, 14:04 RewriteRule ver-(.*)\.htm$ page.php?id=$1
Your rewrite rule is meant for „htm“ files.
But you are trying to load a „html“ file.
