PHP error bei backup und awstats
Henning
Post by Henning »
Denke ja
(z.B. Ubuntu 20.04)
Debian 11.5 64bit
KVM (netcup)
(z.B. 22.0 - Build 2366)
22.2 build 2838
Diese Einträge finden sich im php-error.log wieder:
[10-Jul-2022 03:08:24 Europe/Berlin] PHP Warning: preg_match(): Allocation of JIT memory failed, PCRE JIT will be disabled. This is likely caused by security restrictions. Either grant PHP permission to allocate executable memory, or set pcre.jit=0 in /home/keyhelp/www/keyhelp/core/Helper/IpAddress.php on line 158
[10-Jul-2022 03:08:25 Europe/Berlin] PHP Warning: file_put_contents(/etc/awstats/awstats.web1.conf): failed to open stream: Read-only file system in /home/keyhelp/www/keyhelp/cronjob/jobs/statistic.php on line 504
[10-Jul-2022 03:08:38 Europe/Berlin] PHP Warning: file_put_contents(/etc/awstats/awstats.web2.conf): failed to open stream: Read-only file system in /home/keyhelp/www/keyhelp/cronjob/jobs/statistic.php on line 504
[10-Jul-2022 03:08:49 Europe/Berlin] PHP Warning: preg_match(): Allocation of JIT memory failed, PCRE JIT will be disabled. This is likely caused by security restrictions. Either grant PHP permission to allocate executable memory, or set pcre.jit=0 in /home/keyhelp/www/keyhelp/core/Helper/IpAddress.php on line 158
[10-Jul-2022 03:08:50 Europe/Berlin] PHP Warning: preg_match(): Allocation of JIT memory failed, PCRE JIT will be disabled. This is likely caused by security restrictions. Either grant PHP permission to allocate executable memory, or set pcre.jit=0 in /home/keyhelp/www/keyhelp/core/Helper/IpAddress.php on line 158
[31-Jul-2022 00:00:02 Europe/Berlin] PHP Warning: chmod(): No such file or directory in /home/keyhelp/www/keyhelp/functions/functions.main.php on line 2821
[31-Jul-2022 00:00:02 Europe/Berlin] PHP Warning: rename(/home/keyhelp/keyhelp.backup/dumps/tmp.sql,/home/keyhelp/keyhelp.backup/dumps/keyhelp.sql): No such file or directory in /home/keyhelp/www/keyhelp/cronjob/jobs/01-maintenance.php on line 275
[04-Sep-2022 00:00:04 Europe/Berlin] PHP Warning: chmod(): No such file or directory in /home/keyhelp/www/keyhelp/functions/functions.main.php on line 2821
[04-Sep-2022 00:00:04 Europe/Berlin] PHP Warning: rename(/home/keyhelp/keyhelp.backup/dumps/tmp.sql,/home/keyhelp/keyhelp.backup/dumps/keyhelp.sql): No such file or directory in /home/keyhelp/www/keyhelp/cronjob/jobs/01-maintenance.php on line 275
Das solche Einträge nicht entstehen. Das Log ist nicht gekürzt, die Fehler entstehen also nicht täglich sondern so, wie oben abgebildet 1:1.
Ich denke, das passiert nachts, durch automatisierte Prozesse beim Backup und Erstellung der Statistiken.
Nichts weiter getan.
Was kann ich tun, damit zukünftig solche Fehler wie oben nicht mehr passieren?
Was hat das für Auswirkungen auf mein Produktivsystem?
Vielen Dank für eure Bemühungen im voraus.
Freundliche Grüße von Henning
Re: PHP error bei backup und awstats
Grüße, schau einmal in deinen Thread vom Sommer:
viewtopic.php?t=11538
Blackmoon
Post by Blackmoon »
Könnte dies auf dich zu treffen:
viewtopic.php?p=36525
Henning
Post by Henning »
:roll: danke für den Hinweis.
Ich habe das jetzt nochmal eben gecheckt, meine aktuelle logrotate.service sieht wie folgt aus:
[Unit]
Description=Rotate log files
Documentation=man:logrotate(8) man:logrotate.conf(5)
ConditionACPower=true
[Service]
Type=oneshot
ExecStart=/usr/sbin/logrotate /etc/logrotate.conf
# performance options
Nice=19
IOSchedulingClass=best-effort
IOSchedulingPriority=7
# hardening options
# details: https://www.freedesktop.org/software/sy ... .exec.html
# no ProtectHome for userdir logs
# no PrivateNetwork for mail deliviery
# no ProtectKernelTunables for working SELinux with systemd older than 235
# no MemoryDenyWriteExecute for gzip on i686
PrivateDevices=true
PrivateTmp=true
ProtectControlGroups=true
ProtectKernelModules=true
ProtectSystem=full
RestrictRealtime=true
# Exception so that AWStats works without complaints
ReadWritePaths=/etc/awstats
Insbesondere letzteres fehlte ja am Anfang, steht aber weiterhin mit drin.
