PHP Imagick mit HEIC Support  [GELÖST]
jmkey
Post by jmkey »
derzeit sind die PHP-Versionen von Keyhelp ohne HEIC Support kompiliert. So dass z.B. bei Nextcloud keine Vorschaubilder von HEIC - Bildern generiert werden können.
imagick module	enabled
imagick module version 	3.5.0
imagick classes 	Imagick, ImagickDraw, ImagickPixel, ImagickPixelIterator, ImagickKernel
Imagick compiled with ImageMagick version 	ImageMagick 6.9.10-23 Q16 x86_64 20190101 https://imagemagick.org
Imagick using ImageMagick library version 	ImageMagick 6.9.10-23 Q16 x86_64 20190101 https://imagemagick.org
ImageMagick copyright 	© 1999-2019 ImageMagick Studio LLC
ImageMagick release date 	20190101
ImageMagick number of supported formats: 	235
ImageMagick supported formats 	3FR, 3G2, 3GP, AAI, AI, ART, ARW, AVI, AVS, BGR, BGRA, BGRO, BIE, BMP, BMP2, BMP3, BRF, CAL, CALS, CANVAS, CAPTION, CIN, CIP, CLIP, CMYK, CMYKA, CR2, CRW, CUR, CUT, DATA, DCM, DCR, DCX, DDS, DFONT, DJVU, DNG, DOT, DPX, DXT1, DXT5, EPDF, EPI, EPS, EPS2, EPS3, EPSF, EPSI, EPT, EPT2, EPT3, ERF, EXR, FAX, FILE, FITS, FRACTAL, FTP, FTS, G3, G4, GIF, GIF87, GRADIENT, GRAY, GRAYA, GROUP4, GV, H, HALD, HDR, HISTOGRAM, HRZ, HTM, HTML, HTTP, HTTPS, ICB, ICO, ICON, IIQ, INFO, INLINE, IPL, ISOBRL, ISOBRL6, JBG, JBIG, JNG, JNX, JPE, JPEG, JPG, JPS, JSON, K25, KDC, LABEL, M2V, M4V, MAC, MAGICK, MAP, MASK, MAT, MATTE, MEF, MIFF, MKV, MNG, MONO, MOV, MP4, MPC, MPEG, MPG, MRW, MSL, MSVG, MTV, MVG, NEF, NRW, NULL, ORF, OTB, OTF, PAL, PALM, PAM, PANGO, PATTERN, PBM, PCD, PCDS, PCL, PCT, PCX, PDB, PDF, PDFA, PEF, PES, PFA, PFB, PFM, PGM, PGX, PICON, PICT, PIX, PJPEG, PLASMA, PNG, PNG00, PNG24, PNG32, PNG48, PNG64, PNG8, PNM, PPM, PREVIEW, PS, PS2, PS3, PSB, PSD, PTIF, PWP, RADIAL-GRADIENT, RAF, RAS, RAW, RGB, RGBA, RGBO, RGF, RLA, RLE, RMF, RW2, SCR, SCT, SFW, SGI, SHTML, SIX, SIXEL, SPARSE-COLOR, SR2, SRF, STEGANO, SUN, SVG, SVGZ, TEXT, TGA, THUMBNAIL, TIFF, TIFF64, TILE, TIM, TTC, TTF, TXT, UBRL, UBRL6, UIL, UYVY, VDA, VICAR, VID, VIFF, VIPS, VST, WBMP, WEBP, WMF, WMV, WMZ, WPG, X, X3F, XBM, XC, XCF, XPM, XPS, XV, XWD, YCbCr, YCbCrA, YUV
Grüße,
JM
Re: PHP Imagick mit HEIC Support  [GELÖST]
Grüße,
Zur Information, es hat nichts mit den kompilierten PHP-Versionen zu tun.
Die installierte ImageMagick Version auf dem Server bestimmt die Kompatibilität mit Heic.
Auf modernen Betriebssystemen wie Debian 11 und Ubuntu 22 steht ImageMagick mit Heic Support in den Standard-Repositories zur Verfügung.
Möchtest du auf einem älteren Betriebssystem Heic nutzen, musst du dort eine neuere ImageMagick Version installieren (bzw. selbst kompilieren).
Alternativ kannst du auch ein Dist-Upgrade durchführen um damit die neuste ImageMagick Version zu installieren.
Mit dem Konsolenbefehl prüft du, ob Heic innerhalb vom ImageMagick auf deinem System zur Verfügung steht:
identify -version
