Mail server - instalation  [SOLVED]
Mailserver
Post by Mailserver »
I bought a domain and a VPS server for self-configuration.
Then I installed the KeyAdmin admin panel on the VPS server.
On the domain side, I configured all DNS records and the administration decided that everything was fine.
Currently, I do not receive an e-mail to my inbox that I created in the admin panel, but I can send messages.
Can anyone help me, how should I configure the VPS server to be able to receive messages as well?
Re: Mail server - instalation
is the MX record really correct?
Have you checked the Maillog?
Mailserver
I am an amateur when it comes to knowing the configuration.
Last time I was able to configure it correctly, now I have a problem.
What caught my attention is the fact that in the cockpit in the keyadmin panel I have three domains:
1.domain.pl
2.server2.domena.pl
3.user.serwer.domena.pl
is it ok?
do you have maybe any instruction how to configure it?
there are 2 important things that you can receive mails:
1. The MX Record of the domain must point to your server
2. You create mailboxes in Keyhelp for this domain
You can provide access data via PM so I can check it directly on your server.
Mailserver
Florian wrote: Wed 5. Oct 2022, 12:45 Hallo,
Hello, I sent to you a private message, thank you for help in advance!
Re: Mail server - instalation  [SOLVED]
Cause: Wrong MX record
