Error, Fail Upgrade Ubuntu 20.04 LTS to Ubuntu 22.04 LTS
Tony20
Post by Tony20 »
Trying to do a Upgrade Ubuntu 20.04 LTS to Ubuntu 22.04 LTS
The upgrade fail. I am getting a blank page on panel.mysite.com
I am getting this error.
root@server1:~# php keyhelp_ubuntu_upgrade_20_to_22.php
PHP Fatal error: The file /home/keyhelp/www/keyhelp/init/init_cli.php encoded a s type [1/81] cannot be decoded by this version of the ionCube Loader.
in Unknown on line 0
Fatal error: The file /home/keyhelp/www/keyhelp/init/init_cli.php encoded as typ e [1/81] cannot be decoded by this version of the ionCube
Loader.
I am running KeyHelp 22.2
Server OS: Ubuntu 20.04.5 LTS (GNU/Linux 5.4.0-128-generic x86_64)
Re: Error, Fail Upgrade Ubuntu 20.04 LTS to Ubuntu 22.04 LTS
Please explain in detail, which steps you have performed. What error messages may occurred in the process etc.
And out of curiosity, please answer this: Why didn't you fill out the bug report template?
With your current explanation, I can just guess. - Maybe you forgot Step 3 - "phpenmod ioncube".
Tony20
Post by Tony20 »
Hello, Alexander!
This is what I did.
step -1
wget --no-check-certificate https://install.keyhelp.de/scripts/keyh ... o_22_php71 -O keyhelp_ubuntu_upgrade_20_to_22.php
step -2
The upgrade froze after a few minutes I hit Ctrl +c and rebooted the server.
After reboot
step -3
phpenmod ioncube
step -4
Fatal error: The file /home/keyhelp/www/keyhelp/init/init_cli.php encoded as typ e [1/81] cannot be decoded by this version of the ionCube Loader.
"And out of curiosity, please answer this: Why didn't you fill out the bug report template?"
My bad, I am sorry, Did not read the instructions, I thought it was to make sure I list the KeyHelp and OS Version. .. I will make sure I read carefully next time.
Tony.
Tony20 wrote: Thu 13. Oct 2022, 12:14 The upgrade froze after a few minutes I hit Ctrl +c and rebooted the server.
With this, you have canceled the actual upgrade process. Therefor the server should be still on Ubuntu 20.
Try the following: Call the command "do-release-upgrade" and see if it will start the upgrade process. If yes, very good, after it has finished (and after the reboot), do the steps of "Step 3".
