Email notifications don’t sending
alamis
Post by alamis »
the panel does not send any email notifications
What iam configured?
christian.john
Re: Email notifications don’t sending
Post by christian.john »
My magic crystal ball is broken. Sorry.
Possible options:
1. wrong mail adress
2. disabled running jobs
3. wrong mail konfiguration
4. misconfigured firewall
5. blocked ports by your hoster
6. your server is blocked by an rbl because of spam
7. your server is offline
8. KH is not correct installed.
It would be easier if you post some more informationen than only one sentence. Tell us something about your os, about your configuration. Have you checked your logfiles? Do they show any errors?
@alamis, You show very little effort / initiative with your posts. You want help, so you have to describe the issue in detail.
Also, what happend to the word "thank you" when an issue of you was solved by one of the users here?
I don't like other community members in this forum sacrifice their valueable time in order to ask every detail explicitly from you.
Please consider the above points, or I will act accordingly in upcoming posts from you.
alamis
Post by alamis »
christian.john wrote: Fri 14. Oct 2022, 08:22 My magic crystal ball is broken. Sorry.
Possible options:
5. blocked ports by your hoster- 25 port is opened. Right ?
All configuration is by default.
Use debian 11.
If you mean about log files from admin panel there no error
alamis
Post by alamis »
Alexander wrote: Fri 14. Oct 2022, 09:26 @alamis, You show very little effort / initiative with your posts. You want help, so you have to describe the issue in detail.
You right 😉😉
