ps2pdf how to get it working
napisok
Post by napisok »
Hi, I have a webpage where I had edit the open_basedir settings in the user details and the webepage could see the files. But now it wont start the ps2pdf. It is a debian 11 with keyhelp.
Did not know how to get working, tried to add the place of ghost script in the open basedir setting. But it did not work.
Tried a clean install without keyhelp on debian and it worked. So it must be a settings in keyhelp I need to correct, but how and there.
Thanks for support.
Re: ps2pdf how to get it working
Please share some error logs with us.
napisok
Post by napisok »
Hi I would like to do it. But cannot find any log where I can see it. I have a website there is a button to print pdf via ps2pdf and it just say cannot "pdf file not found, are you sure ps2pdf is installed. The website can see ps2pdf in /usr/bin/ but cannot use it.
I use myself ps2pdf via exec() without any issues.
Are you sure the path to PDF is correct?
napisok
Post by napisok »
Hi, what do you mean with
Is there another place to change?
