Reinstall Problem  [SOLVED]
Re: Reinstall Problem
Hello
My advice:
1) Do the database dumps from the console with the mysqldump command.
2) Store the dumps somewhere (not on the server)
3) Reset the server to a clean state
4) Install KeyHelp
5) Create the client accounts you like
6) Import the database dumps.
execute
keyhelp login
That provides you with a login URL
What is the output of these commands:
ls -la /home/keyhelp/
ls -la /home/keyhelp/www/
ls -la /home/keyhelp/www/keyhelp/
Re: Reinstall Problem  [SOLVED]
This should allow access to the Control-Panel
chown keyhelp:www-data /home/keyhelp/
Just to check, what about these commands?
ls -la /usr/bin/keyhelp
ls -la /home/keyhelp/www/keyhelp/bin/
