Upgrade from Ubuntu 20 >22  [SOLVED]
martins
Post by martins »
I suddenly answered 'NO' for upgrade through SSH during the script execution, because I run the script via SSH . When I try to run the script again directly on the server, it gave me the error below:
sudo php keyhelp_ubuntu_upgrade_20_to_22.php
PHP Fatal error:  The file /home/[user]/keyhelp_ubuntu_upgrade_20_to_22.php encoded as type [1/81] cannot be decoded by this version of the ionCube Loader.
 in Unknown on line 0
What should I do?
Thank You!
Re: Upgrade from Ubuntu 20 >22  [SOLVED]
Just call the console command
do-release-upgrade
Than you are basically at step 2 (https://www.keyhelp.de/news/upgrade-ubu ... ubuntu-22/).
Proceed the guide from step 2 until you have finished all the steps.
martins
Post by martins »
Thank You Alexander!
The issue has been resolved.
