Email Problem
Re: Email Problem
go to the SSH console and check that the name resolution is working on your server.
If not, set other nameservers in /etc/resolv.conf
BasHeijermans
Re: Email Problem
Post by BasHeijermans »
Why do you include 'search invalid'?
That is not normal, I would remove that.
Greetings Bas.
