Problem generating csr  [SOLVED]
rs19
Post by rs19 »
Since it says undefined array key within an keyhelp generated file - i think yes - but no guarantees
Ubuntu 22.04.1 LTS
22.2 - Build 2838
Submitting "Save" in the "Add SSL/TLS Certificate" leads to
Ungültige SSL/TLS-Komponente Privater Schlüssel > Invalid SSL/TLS Component Private Key
Ungültige SSL/TLS-Komponente . > Invalid SSL/TLS Component .
Expected result
Actual result
None
Steps to reproduce
Basic Install on 22.04 and dns settings at the domain provider
Additional information
in /var/log/keyhelp/php-error.log it says
Undefined array key "csr" in /home/keyhelp/www/keyhelp/pages/ssl_certificates.php on line 516
Checking out line 516 in the ssl_certificates.php ist basically a normal line within an certificate.
Im not an expert and any form of input his highly appreciated. But im not using it keyhelp the first time and never ran in to that.
In this case Happy New Year everyone.
Re: Problem generating csr  [SOLVED]
Hello and Happy new year too ;).
Thanks for reporting.
I have found the issue. It is caused by slightly changed behavior of some of the the PHP openssl_* functions on PHP >= 8.0. So only Ubuntu 22 Systems were affected by this.
The issue is now fixed and will be part of the upcoming update. Until then, you can create the CSR via console and regular Linux commands and import it as text into KeyHelp.
The error "Undefined array key "csr" in /home/keyhelp/www/keyhelp/pages/ssl_certificates.php on line 516" is caused by a missing translation, which is now fixed too.
rs19
Post by rs19 »
Thank you for looking into this that quick - especially over these days.
