installing on arm64  [SOLVED]
WolfTongue
installing on arm64
Post by WolfTongue »
Hi there,
some days ago I got an arm64 server (oracle cloud) and wanted to do something with it. As keyhelp supports arm64 (more or less) I thought it would be a good idea to install it on this system.
After some tries and reinstalls I figured out what to do to install it on those minimal ubuntu environments. At the moment it seems to work very fine.
For now I only know some differences to a normal system:
  • PHP interpreters cannot be used (they are only served as x86 or x64 which cannot run under arm)
Link to my how to: https://github.com/MyUncleSam/KeyhelpOnOracleCloud
hzm120
Re: installing on arm64
Post by hzm120 »
even tho this post is old, this link is no longer working..
(Mod/Admin) can u remove the link and close this out?
Re: installing on arm64  [SOLVED]
