KeyHelp Panel shows Update available. (How-to)
BasHeijermans
Post by BasHeijermans »
Hi all,
I went into my panel and saw that there was an update for the KeyHelp panel to 23.0.
I could not find how to update it to the latest version.
So I started the 'keyhelp-toolbox' from the command-line.
In there: Option 6 Maint-tasks -> 3 Control Panel Update
After it has run, go back to your Admin-panel and it should have updated to 23.0
Sadly there was no explenation or anything when I tried to click on the Green-Update-Message, maybe something to do Alex for the next update :lol:
It runs fine at first sight.
Greetings Bas.
Re: KeyHelp Panel shows Update available. (How-to)
Alternative 1: Go to "Maintenance Intervals -> Control panel update -> click on the Play icon"
Now just wait 1-2 minutes -> done!
Alternative 2: Just wait until the 'Control panel update' job installs the update automatically (this will be the case on upcoming Tuesday 03:00 - 04:00 o'clock)
BasHeijermans wrote:Sadly there was no explenation or anything when I tried to click on the Green-Update-Message, maybe something to do Alex for the next update :lol:
Noted ;)
BasHeijermans
Didn't know that as I never have been waiting for updates before, they just came :lol:
Greetings Bas.
It's only since the last 2-3 versions that Alex does a soft-launch (i.e. updates are not automatically rolled out immediately) - before that it never happened (if you didn't turn off the maintenance run) that an open update was displayed for a longer period of time.
BasHeijermans
Good to know! ;)
Greetings Bas.
Alexander wrote: Fri 20. Jan 2023, 15:25 Alternative 2: Just wait until the 'Control panel update' job installs the update automatically (this will be the case on upcoming Tuesday 03:00 - 04:00 o'clock)
Is this (soft launch) update already required or will there be another full update released on Tuesday?
There is just one update, which went live by now.
