Bug in File Manager  [SOLVED]
rogernet
Bug in File Manager
Post by rogernet »
Version: 23.0
O.S.: Ubuntu 20.04
After the update, which occurred without any apparent problem, the file options box in the file manager no longer works, and when hovering the mouse a screen appears as shown in the print.
Image URL:
https://ibb.co/9pvwwcw
Re: Bug in File Manager  [SOLVED]
Hello Rogério,
Thank you!
The languages Brazilian Portuguese, Chinese Traditional and Chinese Simplified translations were affected.
I have fixed it in the KH 23.0 release files (and also included your updated translation files ;))
For the ones, who already be running 23.0 and want to fix this, just perform the following command:
wget https://install.keyhelp.de/misc/functions.js -O /home/keyhelp/www/keyhelp/theme/bulma/assets/js/functions.js ; chown keyhelp:keyhelp /home/keyhelp/www/keyhelp/theme/bulma/assets/js/functions.js ;
You will also have to clear your Browser cache in order to make it work!
