Fresh install debian11 - problem php8.2 and ioncube  [SOLVED]
albertgarcia
Post by albertgarcia »
I'm doing a install with a fresh debian 11 and it show error because the ioncube.
By default, the install tries to use php8.2, but the problem is that ioncube only supports php 8.1 (https://www.ioncube.com/loaders.php).
I've tried to manually force php 8.1 but then the control panel fails on start for the php versions.
It can be possible to change default php version of the installer to PHP 8.1 ? I think that all fresh installs will have the same problem with ioncube...
You are about to install KeyHelp.
Running system checks...
Installing certificates...
Installing PHP...
Reading package lists... Done
Building dependency tree... Done
Installing KeyHelp...
usermod: no changes
Failed loading /usr/local/ioncube/ioncube_loader_lin_8.2.so:  /usr/local/ioncube/ioncube_loader_lin_8.2.so: cannot open shared object file: No such file or directory
/tmp/keyhelp.tar.gz                               100%[=============================================================================================================>]  16.18M  49.0MB/s    in 0.3s
Installing ionCube...
/tmp/ioncube.tar.gz                               100%[=============================================================================================================>]  13.96M  45.0MB/s    in 0.3s
Run /home/keyhelp/www/keyhelp/install/install.php --installer-version 1
Parse error: syntax error, unexpected identifier "ionCube" in /home/keyhelp/www/keyhelp/install/install.php on line 5
Re: Fresh install debian11 - problem php8.2 and ioncube
the default PHP version in Debian 11 is 7.4.
So when it tries to install 8.2 there were changes in the sources.list
albertgarcia
Re: Fresh install debian11 - problem php8.2 and ioncube  [SOLVED]
The current versions:
/etc/apt/sources.list
deb http://deb.debian.org/debian bullseye main
deb-src http://deb.debian.org/debian bullseye main
deb http://security.debian.org/debian-security bullseye-security main
deb-src http://security.debian.org/debian-security bullseye-security main
deb http://deb.debian.org/debian bullseye-updates main
deb-src http://deb.debian.org/debian bullseye-updates main
deb http://deb.debian.org/debian bullseye-backports main
deb-src http://deb.debian.org/debian bullseye-backports main
/etc/apt/sources.list.d/php.list
deb [signed-by=/usr/share/keyrings/deb.sury.org-php.gpg] https://packages.sury.org/php/ bullseye main
I'm going to reinstall fresh debian 11 and try again... I will update post.
albertgarcia wrote: ↑Mon 23. Jan 2023, 12:33
There you have the reason for your problems.
just switch back to PHP7.4
albertgarcia
Sorry about that. With a fresh Debian 11 install, the default version is PHP 7.4 and everything works perfect.
