Additional PHP version PHP-FPM restart  [SOLVED]
TLoF
Post by TLoF »
I would like to restart the additonal php8.1-fpm on the system from command line. But the systemd says not found. I can restart it from the GUI, but one of the sites bad code stuck so i need to do from a shell script.
Any idea how to do this?
Debian 11, latest keyhelp (23)
Tamás
Re: Additional PHP version PHP-FPM restart  [SOLVED]
/etc/init.d/keyhelp-php81-fpm restart
or
systemctl restart  keyhelp-php81-fpm.service
Ich würde mich nicht drauf verlassen, das SysV init-Scripte ewig unterstützt werden.
systemd ist gekommen um zu bleiben …
