delete user don't delete his repertorie [SOLVED]
stephan-ipt
when i delete user "toto" i have always is directorie
/home/users/toto/www/domain.com
it's normal ?
i must delete manually ?
thanks
stephan
Re: delete user don't delete his repertorie [SOLVED]
No, this is not normal.
But are you sure, you have waited 1 minute, until the background job deletes the user, after you have triggert the deletion via the UI?
stephan-ipt
