email another server [SOLVED]
stephan-ipt
i have domain toto.com on my keyhelp server but mail @toto.com is on another server
on my keyhelp server when i use phpmail to send to contact@toto.com
mail not send
i try to @gmail.com, phpmail send i recevied
i disable dns server on keyhelp, but nothing, phpmail no send to contact@toto.com
can you help me
i don't found to configure mail server externe
thanks
stéphan
Re: email another server [SOLVED]
- technotravel
- KeyHelp Translator
If it is, the server tries to send a mail locally ... so maybe try unticking this option.
Oh, 24unix was faster
stephan-ipt
i see now
when adminsitrator creat domain you have this option
when user create domain i don't see this optin
it's normal ?
thanks
stephan
