Upgrade KeyHelp with new resources
boka003
Post by boka003 »
Hello there,
We have upgraded the disk, ram and number of CPU cores at our VPS.
How we can load new resources inside keyadmin?
Extend disk space?
We dint have much experience with server management, but I hope it is simple to do this.
Best regards
Daniel
Re: Upgrade KeyHelp with new resources
Post by Daniel »
this topic has basically nothing todo with the panel itself.
Anyways, keyhelp does not offer this kind of functionality to adjust relevant physical or logical volumes.
You need to proceed these actions using eigher a live enviroment (parted/gparted/parted magic or any other live enviroment) to extend the disk volumes running in productive through cli/ssh.
It depends on the partition layout and the used filesystem. I assume you're using some default "bare-minimum" consisting of /boot; swap; and "/" with ext4
Then its kinda straight forward and logical to expand the "last" and large / partition that also contains user data. If you are going for eg. gparted or any GUI related partition manager you'll find enough guidelines.
For everything else you should request professional support from your hosting provider or the administrative responsible technicans to proceed these changes.
Always keep in mind before proceeding any actions:
Create Backups and store them externally, not at the server itself.
Daniel Marckardt
