Kein SSL für das Panel nach Neuinstallation
j0w3s
Post by j0w3s »
Ubuntu 22.04
23.1 (Build 3009)
Fehler beim Ausstellen von SSL Zertifikat für das Panel
Funktionierendes SSL
Kein SSL
KeyHelp installieren unter Ubuntu 22.04
Failed to aquire a Let's Encrypt certificate for s01.websens.de.
Verification ended with an error.
Details: 37.114.42.138: Fetching https://s01.websens.de/.well-known/acme ... hOIrrJA-sU: Error getting validation data
Type: urn:ietf:params:acme:error:connection
Full response: {"type":"http-01","status":"invalid","error":{"type":"urn:ietf:params:acme:error:connection","detail":"37.114.42.138: Fetching https:\/\/s01.websens.de\/.well-known\/acme-challenge\/lxbCKXdcUzxpmsFvsB0cpXUc8POFBOspKhOIrrJA-sU: Error getting validation data","status":400},"url":"https:\/\/acme-v02.api.letsencrypt.org\/acme\/chall-v3\/225192465517\/7Bcfqw","token":"lxbCKXdcUzxpmsFvsB0cpXUc8POFBOspKhOIrrJA-sU","validationRecord":[{"url":"http:\/\/s01.websens.de\/.well-known\/acme-challenge\/lxbCKXdcUzxpmsFvsB0cpXUc8POFBOspKhOIrrJA-sU","hostname":"s01.websens.de","port":"80","addressesResolved":["37.114.42.138","2a00:ccc1:102:c3::1"],"addressUsed":"2a00:ccc1:102:c3::1"},{"url":"http:\/\/s01.websens.de\/.well-known\/acme-challenge\/lxbCKXdcUzxpmsFvsB0cpXUc8POFBOspKhOIrrJA-sU","hostname":"s01.websens.de","port":"80","addressesResolved":["37.114.42.138","2a00:ccc1:102:c3::1"],"addressUsed":"37.114.42.138"},{"url":"https:\/\/s01.websens.de\/.well-known\/acme-challenge\/lxbCKXdcUzxpmsFvsB0cpXUc8POFBOspKhOIrrJA-sU","hostname":"s01.websens.de","port":"443","addressesResolved":["37.114.42.138","2a00:ccc1:102:c3::1"],"addressUsed":"2a00:ccc1:102:c3::1"}],"validated":"2023-05-05T13:57:05Z"}
Serverdienste absichern bereits alles auf Lets Encrypt und per Wartunsintervalle bereits neu angestoßen. Kein Erfolg. Auch unter Debian 11 erfolgslos
Re: Kein SSL für das Panel nach Neuinstallation
die IPv6 Adresse 2a00:ccc1:102:c3::1 funktioniert nicht. Der Servername löst aber darauf auf.
