form website use email account username in from of my form
stephan-ipt
Post by stephan-ipt »
hi
my account username is create with email : www@www.fr
in my website for this username, in form i have fields for :
to : yyyy@yyy.fr
but form is send with email of account username www@www.fr not with my from xxx@xxx.fr in my form
have option for don't use email of account username ?
thanks
stéphan
stephan-ipt
Re: form website use email account username in from of my form
i found
keyhelp force sendmail path
i see in php.ini
how to disable please
Halo,
you mean sendmail_from???
You can set the sendmail_from in the Keyhelp user settings -> Tab PHP
If sendmail_from is not set and your PHP script does not set a sender, the mail address of the user in the tab "General" is used.
stephan-ipt
thanks
