SSL for hostname/server control panel
Even though I have the following set for "Secure server services" i'm still getting SSL error while i try to access my control panel
Screenshot: https://jumpshare.com/v/uwvSYharOv78HGrutss1
What could be wrong here?
Re: SSL for hostname/server control panel
More Input please!
is the hostname pointing to the correct IPs?
then have a look into System Status -> Event Logs, and Logs -> Maintenance of SSL/TLS certificates
Hi again,
Thank you for replying, my DNS is hosted by Cloudflare and it's pointed correctly to the IP of the server the Cloudflare proxy is off as well using DNS ONLY.
I can load the control panel with ssl error notice in the browser.
But in Keyhelp I get the following error: https://jumpshare.com/v/paG6Cs6p78BwPVmkeZ0g
root@storage:~# ping storage.domain.com
PING storage.domain.com (10.1.1.233) 56(84) bytes of data.somehow the hostname is pinging from 10.1.1.233
