Added PHP 8.1 Extensions. Will they be lost on updates? [SOLVED]
Using Keyhelp latest v.23.x on Ubuntu 22.04 and by default after installation, the first domain I create was using by default PHP 8.1.2 , that is perfect for my case, since is the version I need for my application.
But the application also needed 3 PHP extensions that where not present. So, I have manually installed them using SSH with the commands below.
After some initial tests, all seems to be working perfect!
apt install php-gmp
apt install php-imap
apt install php-mailparse
My only question is if these 3 extensions be lost when KeyHelp control panel performs its automatic updates (or every time PHP 8.1.x is automatic updated)? If yes, any idea or advice on how not to lose them on updates?
Thanks
Re: Added PHP 8.1 Extensions. Will they be lost on updates? [SOLVED]
No.
