post_max_size and upload_max_filesize
Crossfire
Post by Crossfire »
Hi!
I set up upload_max_filesize and post_max_size to 512M in keyhelp, also in php.ini i set it up, but i still get these values:
post_max_size 128M
upload_max_filesize 256M
Also set PHP time limit to 120 but it is still 60.
I restarted all services and reboot the server.
Pictures attached.
Anyone knows what could be the problem?
wp sitehealth.png (14.33 KiB) Viewed 2135 times
Re: post_max_size and upload_max_filesize
If you change the template afterwards it does not affect existing customers.
You must change the user php settings.
Tobi wrote: Sun 23. Jul 2023, 18:21 You must change the user php settings.
... or re-apply the account template in the user management of the corresponding users.
