Migration server from Datacenter to enother one - Change IP  [SOLVED]
gusarg81
Post by gusarg81 »
We migrated our server to another Datacenter. Our server rungs on Ubuntu 22.04. So I've changed the IP with netplan.
Is there a way under console to change IP settings, DNS, etc on Keyhelp?
Thanks in advance.
Re: Migration server from Datacenter to enother one - Change IP  [SOLVED]
not yet. It will come with one of the next updates.
For now you can use the following command to change the IPs in the database:
mysql -D 'keyhelp' -e "UPDATE settings SET value = '111.111.111.111,222.222.222.222' WHERE category = 'dns' and name = 'ips'";
Of course you must switch 111.111.111.111 and 222.222.222.222 to your real IPs.
After that run keyhelp-toolbox -> Rewrite user configuration files (Apache / Bind9 / PHP-FPM)
