Antiviren-Scan schlägt immer fehl  [GELÖST]
xeppel
Post by xeppel »
(z.B. Ubuntu 20.04)
Debian 11.7
(z.B. 22.0 - Build 2366)
23.1.1 (Build 3016)
Der wöchentliche Antiviren-Scan schlägt immer fehl. Er hat noch nie funktioniert.
Erfolg.
Abort, anti virus scanner failed.
------------- AV SCAN --------------
Start: 2023-09-23 01:00:01
---------- SCAN LOCATIONS ----------
/home/users
/tmp
/var/tmp
------ UPDATE VIRUS DATABASE -------
End: 2023-09-23 01:00:44
Status: Success
--------------- END ----------------
End: 2023-09-23 01:05:09
Status: Abort, anti virus scanner failed.
Sat Sep 23 01:00:01 2023 -> --------------------------------------
Sat Sep 23 01:00:01 2023 -> ClamAV update process started at Sat Sep 23 01:00:01 2023
Sat Sep 23 01:00:01 2023 -> daily.cld database is up-to-date (version: 27039, sigs: 2041306, f-level: 90, builder: raynman)
Sat Sep 23 01:00:01 2023 -> main.cvd database is up-to-date (version: 62, sigs: 6647427, f-level: 90, builder: sigmgr)
Sat Sep 23 01:00:01 2023 -> bytecode.cvd database is up-to-date (version: 334, sigs: 91, f-level: 90, builder: anvilleg)
Sat Sep 23 01:00:11 2023 -> junk.ndb is up-to-date (version: custom database)
Sat Sep 23 01:00:13 2023 -> jurlbl.ndb is up-to-date (version: custom database)
Sat Sep 23 01:00:14 2023 -> phish.ndb is up-to-date (version: custom database)
Sat Sep 23 01:00:16 2023 -> rogue.hdb is up-to-date (version: custom database)
Sat Sep 23 01:00:17 2023 -> sanesecurity.ftm is up-to-date (version: custom database)
Sat Sep 23 01:00:19 2023 -> sigwhitelist.ign2 is up-to-date (version: custom database)
Sat Sep 23 01:00:20 2023 -> scam.ndb is up-to-date (version: custom database)
Sat Sep 23 01:00:21 2023 -> spamimg.hdb is up-to-date (version: custom database)
Sat Sep 23 01:00:22 2023 -> spamattach.hdb is up-to-date (version: custom database)
Sat Sep 23 01:00:24 2023 -> blurl.ndb is up-to-date (version: custom database)
Sat Sep 23 01:00:25 2023 -> foxhole_generic.cdb is up-to-date (version: custom database)
Sat Sep 23 01:00:26 2023 -> foxhole_filename.cdb is up-to-date (version: custom database)
Sat Sep 23 01:00:27 2023 -> malwarehash.hsb is up-to-date (version: custom database)
Sat Sep 23 01:00:29 2023 -> hackingteam.hsb is up-to-date (version: custom database)
Sat Sep 23 01:00:30 2023 -> winnow_malware.hdb is up-to-date (version: custom database)
Sat Sep 23 01:00:31 2023 -> winnow_malware_links.ndb is up-to-date (version: custom database)
Sat Sep 23 01:00:33 2023 -> winnow_extended_malware.hdb is up-to-date (version: custom database)
Sat Sep 23 01:00:34 2023 -> winnow.attachments.hdb is up-to-date (version: custom database)
Sat Sep 23 01:00:35 2023 -> winnow_bad_cw.hdb is up-to-date (version: custom database)
Sat Sep 23 01:00:36 2023 -> bofhland_cracked_URL.ndb is up-to-date (version: custom database)
Sat Sep 23 01:00:38 2023 -> bofhland_malware_URL.ndb is up-to-date (version: custom database)
Sat Sep 23 01:00:39 2023 -> bofhland_phishing_URL.ndb is up-to-date (version: custom database)
Sat Sep 23 01:00:40 2023 -> bofhland_malware_attach.hdb is up-to-date (version: custom database)
Sat Sep 23 01:00:41 2023 -> porcupine.ndb is up-to-date (version: custom database)
Sat Sep 23 01:00:43 2023 -> porcupine.hsb is up-to-date (version: custom database)
Sat Sep 23 01:00:44 2023 -> phishtank.ndb is up-to-date (version: custom database)
Sat Sep 23 01:00:44 2023 -> Testing database: '/var/lib/clamav/tmp.0832113b47/clamav-689b8ae866a17dec612a22074cd473c1.tmp-urlhaus.ndb' ...
Sat Sep 23 01:00:44 2023 -> Database test passed.
Sat Sep 23 01:00:44 2023 -> urlhaus.ndb updated (version: custom database, sigs: 3895)
Sat Sep 23 01:00:44 2023 -> WARNING: Clamd was NOT notified: Can't connect to clamd through /var/run/clamav/clamd.ctl: No such file or directory
root@vps:/home/user# sudo systemctl status clamav-daemon.service
● clamav-daemon.service - Clam AntiVirus userspace daemon
     Loaded: loaded (/lib/systemd/system/clamav-daemon.service; disabled; vendor preset: enabled)
    Drop-In: /etc/systemd/system/clamav-daemon.service.d
             └─extend.conf
     Active: inactive (dead)
       Docs: man:clamd(8)
             man:clamd.conf(5)
             https://docs.clamav.net/
Sep 15 03:09:11 vps.XXXXXX.tld systemd[1]: /lib/systemd/system/clamav-daemon.service:12: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
Sep 17 06:25:02 vps.XXXXXX.tld systemd[1]: /lib/systemd/system/clamav-daemon.service:12: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
Sep 23 10:45:01 vps.XXXXXX.tld systemd[1]: /lib/systemd/system/clamav-daemon.service:12: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
Sep 23 10:45:09 vps.XXXXXX.tld systemd[1]: /lib/systemd/system/clamav-daemon.service:12: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
Unter " /var/run" gibt es nicht einmal den Ordner "clamav".
Re: Antiviren-Scan schlägt immer fehl  [GELÖST]
Setz den Dienst mal zurück:
sudo systemctl stop clamav-daemon.service
sudo rm /var/log/clamav/freshclam.log
service sudo systemctl start clamav-daemon.service
Und jetzt nochmal schauen, ob der Dienst aktiv ist:
xeppel
Post by xeppel »
danke, läuft!
@Alexander:
Das Problem tritt ja öfter auf und hat als Ursache, daß das Logfile nicht freigegeben wurde.
Kann man das seitens KeyHelp abfangen, um diese Fehlerquelle zu eliminieren?
Ein händisches Löschen des Logfiles zur Fehlerbehebung ist ja nun auch nicht das Gelbe vom Ei... :?
Es gab kürzlich einige Updates bei den clamav packages, danach gab es auch hier Aussetzer.
Habe auch den Eindruck die scans brauchen seitdem etwas länger ...
Prüfe mal die Anzahl der Files in den Webs, könnte auch durch fehlerhafte Cache settings von CMS oder Shops verursacht werden wo die cached files nicht gelöscht werden und sich prächtig vermehren oder in den User /tmp durch Fehler oder Attacken sich einiges angesammelt hat.
find /home/users -xdev -type d -print | xargs -n1 du --inodes -sS | sort -rn | head -10
