Default database collation should be utf8_unicode_ci
The 'Server connection collation' is already utf8mb4_unicode_ci utf8mb4_unicode_ci is a much more efficient search algorithm and the extra overheads are minimal. This is also the standard collation that WordPress now uses for its tables where it can.
I can probably figure out how to change this myself, but for new installs this should be set tot he new collation of utf8mb4_unicode_ci
shoulders
Re: Default database collation should be utf8_unicode_ci
it is the default setting of MariaDB. Keyhelp does not change anything here.
For reference:
Then the DBA should use what he likes better, you can change it anytime. The defaults are not really important.
You may want to ask the operating system vendors, why they set the default to utf8mb4_general_ci instead of utf8mb4_unicode_ci.
I had a look:
- Ubuntu 22 uses utf8mb4_general_ci
- Debian 12 uses utf8mb4_general_ci
