File Manager - Add refresh button [SOLVED]
Please add a refresh button to the file manager.
Re: File Manager - Add refresh button [SOLVED]
This is why most of the other panels I have evaluated have this feature.
If it is not a big thing you could:
- add a javascript button that refreshes the page and just call it 'Refresh'
- or add a small note to advise users that they can use F5 to refresh and the location will be maintained.
On mobile devices you only need a swipe gesture to refresh the web page.
And sorry, if you don't even know such simple things, then you shouldn't manage servers.
I think the file manager is not really meant for the admin, I've never ever used it.
Nothing beats the shell.
Or in this specific case also a FTP Client like Filezilla, WinSCP, whatever...
I know how to refresh a page but I would not expect a folder reference in a GET request.
The end-user will definitely not know to examine the URL for such data and then decide, ahah I should refresh the page, all those other panels with a refresh button are stupid.
I know how to do a few things, but you get me mixed up with clients. You have a client area for a reason. The file manger is only available in the client area.
Hope this clears things up.
You say, that clients assumes, when he hit F5, we will be redirected to an other directory / reset their current directory.
I would say, clients, who use KeyHelp do not have to worry about this, they can just hit F5 and everything will be fine.
If other control panels make the user think about a refresh button an a possible reset of their current directory than that is the fault of the respective panels. In KeyHelp F5 just works.
File managers come in 2 basic forms (as you know)
- PHP based, all updates are done by hyperlink and the supply of a new page from the PHP interpreter etc.. A page refresh has occurred (your file manager I am guessong). This will be controlled by variables POST or GET (GET for yours) supplied with the REQUEST.
- then there is the ajax based stuff where the 'new code' is supplied in the background, the DOM is altered and you stay on the same html/php page, no page refresh occurs.
If you hit F5 on a file manager that is using ajax the location/folder data will not be sent over a GET variable and the page will reload fresh.
The reason I expected a refresh button is that when I click on a folder or the up directory button the page refresh is so quick I did not see it or perhaps I thought the file manager was being update by ajax. I did not feel the need to inspect the URL to see GET variables to discover the file manager was PHP based.
I completely understand now that F5 just works (even though I would prefer a button
P.s. I appreciate the feedback I have been given aswell.
If you have to refresh all the time, you are doing something wrong.
sorry
