Add PHP version in cpanel KeyHelp PHP Interpreter  [SOLVED]
[RGK]*Kent
Post by [RGK]*Kent »
I installed Keyhelp, and I am facing a problem.
After installing other versions on PHP ex php 7.1.
I don't know how I can add them to the keyhelp panel to use them on different domains/subdomains
All privileges are granted by the administrator!
Please help.
Thank you!
Re: Add PHP version in cpanel KeyHelp PHP Interpreter  [SOLVED]
Those who can read are at an advantage!
It is displayed to you on an exposed place, right? :(
