Changed NIC IP, KeyHelp domain DNS has not updated
shoulders
Post by shoulders »
yes
Linux khdebian.mydomain.com 6.1.0-13-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.55-1 (2023-09-29) x86_64
TrueNAS / KVM
23.2 (Build 3097)
While testing my KeyHelp on my local network the DHCP address it got was 10.0.0.137 which worked as expected. I then changed the IP to a static IP address of 10.0.0.250
I connected into the server (10.0.0.250) by using puttty/SSH and when I log in I am greeted with
  This server is powered by KeyHelp!
  * Control panel access:
      https://khdebian.mydomain.com
      https://10.0.0.137
  * Login data:
      /root/keyhelp_login_data_*
  * CLI utilities:
      # keyhelp
      # keyhelp-toolbox
IP a
root@khdebian:~# ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host noprefixroute
2: ens3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
    link/ether 00:xx:xx:xx:xx:xx brd ff:ff:ff:ff:ff:ff
    altname enp0s3
    inet 10.0.0.250/24 brd 10.0.0.255 scope global ens3
    inet6 fe80::xxx:xxxx:xxxx:xxxx/64 scope link
root@khdebian:~#
So I went to 'Settings --> Configuration --> System --> IP Addresses' and update as required.
Expected result
All domains to have the 10.0.0.137 IP in their DNS updated to 10.0.0.250
The login details as shown above to show
      https://10.0.0.250
Actual result
All domains were updated to 10.0.0.250 except the KeyHelp domain khdebain.mydomain.com which is still on 10.0.0.137
Steps to reproduce
Change the network card IP address via the command line.
Additional information
This is a fresh copy of KeyHelp that I am messing about with.
There is no way to edit the DNS zone through KeyHelp and the IP update process does not update the KeyHelp domain.
I have not tried changing it in the config files manually as I think this is a bug.
Re: Changed NIC IP, KeyHelp domain DNS has not updated
This is probably not a bug since the motd is actually only generated at setup.
Changes are up to come.
Sorry for that, but the followup is in german languange.
This way please: viewtopic.php?t=12663
