Posts: 1472 Joined: Mon 30. Mar 2020, 16:14
Post
by Ralph » Sun 19. Nov 2023, 17:32
Habe für BLACKLIST_SENDER_EMAIL etwas abgeändert damit es auch bei envelope greift (möglicherweise auch bei der whitelist address nötig) ansonsten alles vorhin gestestet - sollte funktionieren.
touch /etc/rspamd/local.d/whitelist.sender.domain.map
touch /etc/rspamd/local.d/whitelist.sender.email.map
touch /etc/rspamd/local.d/blacklist.sender.domain.map
touch /etc/rspamd/local.d/blacklist.sender.email.map
touch /etc/rspamd/local.d/blockip.map
touch /etc/rspamd/local.d/allowip.map
nano /etc/rspamd/local.d/multimap.conf
WHITELIST_SENDER_DOMAIN {
type = "from";
filter = "email:domain";
map = "${LOCAL_CONFDIR}/local.d/whitelist.sender.domain.map";
action = "accept";
symbol = "WHITELISTED_DOMAIN";
WHITELIST_SENDER_EMAIL {
type = "from";
map = "${LOCAL_CONFDIR}/local.d/whitelist.sender.email.map";
action = "accept";
symbol = "WHITELISTED_ADDRESS";
BLACKLIST_SENDER_DOMAIN {
type = "from";
map = "${LOCAL_CONFDIR}/local.d/blacklist.sender.domain.map";
action = "reject";
symbol = "BLACKLISTED_DOMAIN";
BLACKLIST_SENDER_EMAIL {
type = "header";
header = "From";
filter = "email";
map = "${LOCAL_CONFDIR}/local.d/blacklist.sender.email.map";
action = "reject";
symbol = "BLACKLISTED_ADDRESS";
regexp = "false";
BLOCKLIST_IP {
type = "ip";
map = "${LOCAL_CONFDIR}/local.d/blockip.map";
prefilter = true;
action = "reject";
description = "local block list";
symbol = "BLOCKLIST_IP";
ALLOWLIST_IP {
type = "ip";
map = "${LOCAL_CONFDIR}/local.d/allowip.map";
prefilter = true;
action = "accept";
description = "local allow list";
symbol = "ALLOWLIST_IP";
# whitelist domain
nano /etc/rspamd/local.d/whitelist.sender.domain.map
domainname.tld
# whitelist emailaddress
nano /etc/rspamd/local.d/whitelist.sender.email.map
user@domainname.tld
# blacklist domain
nano /etc/rspamd/local.d/blacklist.sender.domain.map
domainname.tld
# blacklist emailaddress
nano /etc/rspamd/local.d/blacklist.sender.email.map
user@domainname.tld
# blacklist IP:
nano /etc/rspamd/local.d/blockip.map
# einzel ip keine range
111.111.111.111
# whitelist IP:
nano /etc/rspamd/local.d/allowip.map
111.111.111.111
### edit ###
Result & Symbol im Header anzeigen
nano /etc/rspamd/local.d/milter_headers.conf
extended_spam_headers = true;
Posts: 2209 Joined: Sun 21. Jun 2020, 17:16
Post
by 24unix » Sun 19. Nov 2023, 19:00
Slightly OT:
Mir blutet jedesmal das Herz, wenn jemand nano (statt vi) verwendet.
Aber in dem Fall ist ein Heredoc für Copy&Paste doch deutlich einfacher:
cat << 'EOF' > /etc/rspamd/local.d/multimap.conf
type = "from";
map = "\${LOCAL_CONFDIR}/local.d/whitelist.sender.domain.map";
action = "accept";
type = "from";
map = "\${LOCAL_CONFDIR}/local.d/whitelist.sender.email.map";
action = "accept";
type = "from";
map = "\${LOCAL_CONFDIR}/local.d/blacklist.sender.domain.map";
action = "reject";
type = "header";
header = "From";
filter = "email";
map = "\${LOCAL_CONFDIR}/local.d/blacklist.sender.email.map";
action = "reject";
regexp = "false";
BLOCKLIST_IP {
type = "ip";
map = "\${LOCAL_CONFDIR}/local.d/blockip.map";
prefilter = true;
action = "reject";
ALLOWLIST_IP {
type = "ip";
map = "\${LOCAL_CONFDIR}/local.d/allowip.map";
prefilter = true;
action = "accept";
EOF
Post
by Ralph » Sun 19. Nov 2023, 19:06
24unix wrote: ↑ Sun 19. Nov 2023, 19:00
Sicher, kann ja jeder nach belieben tun, ich bin ein überzeugter vi hater ... kommt mir nicht in die Tüte
Post
by 24unix » Sun 19. Nov 2023, 19:11
Ralph wrote: ↑ Sun 19. Nov 2023, 19:06
Dann halt Emacs, aber Nano?
Aber davon abgesehen, Du siehst den Punkt mit dem Heredoc?
technotravel
Posts: 495 Joined: Mon 19. Oct 2020, 11:11
Post
by technotravel » Mon 20. Nov 2023, 10:58
Super - eine Möglichkeit zum Whitelisten such ich auch ... fehlt mir sehr im Panel seit Rspamd
Eine Frage:
user@domainname.tld
Muss denn in der Whitelist eine Mailadresse vollständig eingetragen werden, oder reicht auch ein z.B.
@domainname.tld oder
*@domainname.tld ?
Post
by Ralph » Mon 20. Nov 2023, 11:03
technotravel wrote: ↑ Mon 20. Nov 2023, 10:58
Eine Frage:
user@domainname.tld
*@domainname.tld ?
hier sind einige Beispiele (ungestestet)
https://jeffknerr.github.io/rspamd/rege ... mples.html
Posts: 4835 Joined: Wed 20. Jan 2016, 02:23
Post
by Alexander » Tue 21. Nov 2023, 13:02
Kommt ab nächster Version wieder.
Es werden auch die bis dato gespeicherten (aber für Debian 12 bislang ausgeblendeten) Einstellungen, die über KeyHelp in vorherigen Debian Versionen aktiv waren (Konfiguration -> E-Mail-Server -> Spam-Filter Black-/Whitelist) übernommen.
http://www.keyweb.de -
http://www.keyhelp.de
