Enable/Add Rspamd "per user" learn option
amarc
Post by amarc »
Keyhelp should utilise "per_user" bayes learns in some future release. Currently in statistics.conf there is default value of "min_learns = 200;" which is almost impossible to train Rspamd to this value.
This means that similar email would have to be learned 200 times before Rspamd moves it to Junk. Considering there is no chance spammer would be sending 200 emails with similar headers I suggest:
in statistics.conf:
users_enabled = true;
per_user = true;
min_learns = 2;
Also in dovecot/conf.d/90-sieve.conf (or equivalent) in order to actually learn these email on-the-go (below is just example):
plugin {
    sieve_plugins = sieve_imapsieve sieve_extprograms
    sieve_before = /var/vmail/mail/sieve/global/spam-global.sieve
    sieve = file:/var/vmail/mail/sieve/%d/%n/scripts;active=/var/vmail/mail/sieve/%d/%n/active-script.sieve
    imapsieve_mailbox1_name = Spam
    imapsieve_mailbox1_causes = COPY
    imapsieve_mailbox1_before = file:/var/vmail/mail/sieve/global/report-spam.sieve
    imapsieve_mailbox2_name = *
    imapsieve_mailbox2_from = Spam
    imapsieve_mailbox2_causes = COPY
    imapsieve_mailbox2_before = file:/var/vmail/mail/sieve/global/report-ham.sieve
    sieve_pipe_bin_dir = /usr/bin
    sieve_global_extensions = +vnd.dovecot.pipe
require ["vnd.dovecot.pipe", "copy", "imapsieve"];
pipe :copy "rspamc" ["learn_spam"];
pipe :copy "rspamc" ["learn_ham"];
Also, currently you might have 1000 email users on server and all "share" same learns. Basically, it is wrong to assume what is Spam for User1 that is also Spam for User1
https://rspamd.com/doc/configuration/statistic.html
