Wildcard Cnames
Wildcard Cnames
We have a very specific use in mind for the software. We have a WordPress-based plugin that creates any number of subdomains within one installation. This is done by using a cname wildcard at the DNS provider, pointed to the single domain install.
Using past control panels, we would accomplish this by doing; *.domain.com. But in this case that creates a subdomain called wildcard.domain.com.
Will the software support the usage we intend? And if so, what's the best way to achieve this?
Thanks
Re: Wildcard Cnames
You can try the following...
Go to Domains >> Domains >> Edit Domain >> Apache Settings, and insert:
ServerAlias *.domain.comData Collector für Community Support
Re: Wildcard Cnames
Is there a way to make this part of the domain template or Apache template? So that it would apply to all domains created.
And if so, could I get instructions for this?
Again, thanks so much!
Re: Wildcard Cnames
About making sure it happens for all domains, I would assume I could do it here:
if I know what to put so that it works for all domains?
