Was bedeutet das ......
fwberni
Post by fwberni »
Hallo
@all
Ein Gesundes Neues Jahr
Debian 12.4 (64-bit)
KH: 23.2.1 (Build 3125)
Heute musste ich im Systemstatus vom Email-Protokoll folgende Meldungen lesen:
Hier möchte wohl jemand man Mailserver Mißbrauchen oder......
2024-01-02 16:24:28	postfix/smtps/smtpd	disconnect from unknown[141.98.11.68] ehlo=1 auth=0/1 rset=1 commands=2/3
2024-01-02 16:24:28	postfix/smtps/smtpd	lost connection after AUTH from unknown[141.98.11.68]
2024-01-02 16:24:21	postfix/smtps/smtpd	warning: unknown[141.98.11.68]: SASL LOGIN authentication failed: UGFzc3dvcmQ6, sasl_username=backup@torstenseiferth.de
2024-01-02 16:24:20	postfix/smtps/smtpd	connect from unknown[141.98.11.68]
2024-01-02 16:24:20	postfix/smtps/smtpd	warning: hostname noiseless.medyamol.com does not resolve to address 141.98.11.68
2024-01-02 16:23:46	postfix/smtps/smtpd	disconnect from unknown[141.98.11.68] ehlo=1 auth=0/1 rset=1 commands=2/3
2024-01-02 16:23:46	postfix/smtps/smtpd	lost connection after AUTH from unknown[141.98.11.68]
2024-01-02 16:23:39	postfix/smtps/smtpd	warning: unknown[141.98.11.68]: SASL LOGIN authentication failed: UGFzc3dvcmQ6, sasl_username=abuse@torstenseiferth.de
2024-01-02 16:23:37	postfix/smtps/smtpd	connect from unknown[141.98.11.68]
2024-01-02 16:23:37	postfix/smtps/smtpd	warning: hostname noiseless.medyamol.com does not resolve to address 141.98.11.68
2024-01-02 16:23:07	postfix/anvil	statistics: max cache size 2 at Jan 2 16:18:24
2024-01-02 16:23:07	postfix/anvil	statistics: max connection count 1 for (smtps:141.98.11.68) at Jan 2 16:13:41
2024-01-02 16:23:07	postfix/anvil	statistics: max connection rate 4/60s for (smtps:123.254.109.92) at Jan 2 16:19:12
2024-01-02 16:23:02	postfix/smtps/smtpd	disconnect from unknown[141.98.11.68] ehlo=1 auth=0/1 rset=1 commands=2/3
2024-01-02 16:23:02	postfix/smtps/smtpd	lost connection after AUTH from unknown[141.98.11.68]
2024-01-02 16:22:55	postfix/smtps/smtpd	warning: unknown[141.98.11.68]: SASL LOGIN authentication failed: UGFzc3dvcmQ6, sasl_username=support@torstenseiferth.de
2024-01-02 16:22:53	postfix/smtps/smtpd	connect from unknown[141.98.11.68]
die hier genannten email Adressen gibt es ja gar nicht !
Und die IP 141.98.11.68 geht nach Litauen. Was kann ich da gegen tun ?
Gruss Torsten
[Mod-Edit]
CODE-Tags eingefügt.
Reason: Mod-Edit
Re: Was bedeutet das ......
Das sieht erstmal nach ganz normalem Grundrauschen aus, da werden Logins auf deinem Server nach Schwachstellen abgeklappert.
Kannst du erstmal ignorieren. Wenn die Zahl solcher Zugriffe massiv zunehmen sollte, kann man da noch an den Einstellungen nachschärfen, ist aber aktuell vermutlich nicht nötig.
fwberni
Post by fwberni »
okay, ich werde es beobachten.
fwberni
Post by fwberni »
Jolinar wrote: Tue 2. Jan 2024, 16:45 Das sieht erstmal nach ganz normalem Grundrauschen aus, da werden Logins auf deinem Server nach Schwachstellen abgeklappert.
also das "Grundrauschen" ist nach wie vor da .
Was kann ich denn da noch nachschärfen in den Einsztellungen ?
fwberni wrote: Wed 3. Jan 2024, 08:28 also das "Grundrauschen" ist nach wie vor da .
Das wird auch immer da sein. Sowas gehört zum Alltag eines Admins, also leb damit... :lol:
fwberni wrote: Wed 3. Jan 2024, 08:28 Was kann ich denn da noch nachschärfen in den Einsztellungen ?
Da gibt es viele Möglichkeiten zum Finetuning.
Zb. könntest du deiner Firewall sagen, daß sie Requests aus der IP-Range von Litauen generell abweisen soll. Du könntest auch die Datenströme mit f2b lenken, indem du entsprechend sensible Jails definierst.
Solche Maßnahmen sollten aber immer gut überlegt und individuell auf das jeweilige Setup abgestimmt sein, damit du nicht mehr Schaden anrichtest als Nutzen generierst, denn zB. mit zu restriktiver Firewall könntest du auch legitime Nutzer von deinen Webpräsenzen aussperren.
Aber ich bin nach wie vor ziemlich sicher, daß du garnicht eingreifen brauchst. :mrgreen: :geek:
Fail2ban strikter konfigurieren und die IP Adresse blockieren
nano /etc/fail2ban/jail.d/keyhelp.local
# Postfix part erweitern
[keyhelp-postfix]
mode = aggressive
findtime = 1800
maxretry = 2
bantime  = 24h
# restart fail2ban
service fail2ban restart
Diese IP Adresse ist bereits länger als attackierend bekannt, also zusätzlich permanent per iptables oder ipset blocken:
141.98.11.68
IP Details:
https://www.abuseipdb.com/check/141.98.11.68
fwberni
Post by fwberni »
Ralph wrote: Wed 3. Jan 2024, 09:12
[keyhelp-postfix]
mode = aggressive
findtime = 1800
maxretry = 2
bantime  = 24h
# restart fail2ban
141.98.11.68
IP Details:
Danke Ralf,
habe es mal gemacht wie oben beschrieben.
Zur Zeit ist Ruhe im Karton. ;) Habe auch unter Firewall die IP komplett gespert
