Database Create Option Not Showing [SOLVED]
I installed KeyHelp Free Control Panel, but I am unable to find the database create option. I tried to find on forums but not found.
Is there any option to enable database create option?
Re: Database Create Option Not Showing
Re: Database Create Option Not Showing [SOLVED]
You may not have not assign the appropriate privileges to the client, to add databases.
Go to the KeyHelp Admin Area -> User Administration -> Click the pen icon on the client you would like to edit -> Go to the "Resources & permission" tab -> Find "Databases" and add any number, or choose 'unlimited' - this determines, how many databases the user will be able to create.
Then switch to the user and you should see the menu item "Databases".
You may want to have a look into the "How To Get Started in KeyHelp" tutorial:
https://www.youtube.com/watch?v=uAxkiiO ... 8P&index=7
The user needs the permissions:
But from admin login I am unable to see Database option. is it restricted to see database list from admin area?
