HTTPS Anweisungen bei Subdomain führen zu Connection Refused auf das KH Panel  [GELÖST]
Dreandor
Post by Dreandor »
Ja
Debian 11.8
23.2.1
Wenn ich meiner Subdomain (mit Let's Encrypt Zertifikat) HTTPS Anweisungen gebe, dann komm ich nicht mehr auf das KH Panel (Connection Refused)
Panel läuft weiterhin und die HTTPS Anweisungen funktionieren
Panel aufruf klappt nicht mehr mit Fehler: Connection Refused
Subdomain erstellen + Let's Encrypt Zertifikat einstellen
In HTTP Anweisungen:
RewriteEngine on
RewriteRule ^ https://%{HTTP_HOST}%{REQUEST_URI} [R=301,L]
In HTTPS Anweisungen:
ProxyPreserveHost On
SSLProxyEngine On
        SSLProxyVerify none
        SSLProxyCheckPeerCN off
        SSLProxyCheckPeerName off
        SSLProxyCheckPeerExpire off
RewriteEngine on
RewriteCond %{HTTP:Upgrade} websocket [NC]
RewriteCond %{HTTP:Connection} upgrade [NC]
RewriteRule .* "wss://127.0.0.1:8443%{REQUEST_URI}" [P]
SSLCertificateFile /var/opt/minecraft/crafty/crafty-4/app/config/web/certs/commander.cert.pem
SSLCertificateKeyFile /var/opt/minecraft/crafty/crafty-4/app/config/web/certs/commander.key.pem
ProxyPass / https://127.0.0.1:8443/
ProxyPassReverse / https://127.0.0.1:8443/
ProxyRequests off
/var/log/keyhelp/php-error.log existiert nicht
php7.4-fpm.log
[25-Jan-2024 09:10:01] NOTICE: Reloading in progress ...
[25-Jan-2024 09:10:01] NOTICE: reloading: execvp("/usr/sbin/php-fpm7.4", {"/usr/sbin/php-fpm7.4", "--nodaemonize", "--fpm-config", "/etc/php/7.4/fpm/php-fpm.conf"})
[25-Jan-2024 09:10:01] NOTICE: using inherited socket fd=7, "/run/php/keyhelp_keyhelp.socket"
[25-Jan-2024 09:10:01] NOTICE: using inherited socket fd=8, "/run/php/keyhelp_dreandor_de.socket"
[25-Jan-2024 09:10:01] NOTICE: fpm is running, pid 585
[25-Jan-2024 09:10:01] NOTICE: ready to handle connections
[25-Jan-2024 09:10:01] NOTICE: systemd monitor interval set to 10000ms
journalctl -xe
░░ Subject: Unit process exited
░░ Defined-By: systemd
░░ Support: https://www.debian.org/support
░░ An ExecStart= process belonging to unit apache2.service has exited.
░░ The process' exit code is 'exited' and its exit status is 1.
Jan 25 09:14:01 panel.dreandor.de systemd[1]: apache2.service: Failed with result 'exit-code'.
░░ Subject: Unit failed
░░ The unit apache2.service has entered the 'failed' state with result 'exit-code'.
Jan 25 09:14:01 panel.dreandor.de systemd[1]: Failed to start The Apache HTTP Server.
░░ Subject: A start job for unit apache2.service has failed
░░ A start job for unit apache2.service has finished with a failure.
░░ The job identifier is 183314 and the job result is failed.
Jan 25 09:14:01 panel.dreandor.de sudo[211979]: pam_unix(sudo:session): session closed for user root
Jan 25 09:14:01 panel.dreandor.de CRON[211945]: pam_unix(cron:session): session closed for user root
Jan 25 09:14:04 panel.dreandor.de systemd[1]: Starting The Apache HTTP Server...
░░ Subject: A start job for unit apache2.service has begun execution
░░ A start job for unit apache2.service has begun execution.
░░ The job identifier is 183379.
Jan 25 09:14:04 panel.dreandor.de apachectl[212000]: Action 'start' failed.
Jan 25 09:14:04 panel.dreandor.de apachectl[212000]: The Apache error log may have more information.
Jan 25 09:14:04 panel.dreandor.de systemd[1]: apache2.service: Control process exited, code=exited, status=1/FAILURE
Jan 25 09:14:04 panel.dreandor.de systemd[1]: apache2.service: Failed with result 'exit-code'.
Jan 25 09:14:04 panel.dreandor.de systemd[1]: Failed to start The Apache HTTP Server.
░░ The job identifier is 183379 and the job result is failed.
Jan 25 09:14:06 panel.dreandor.de dhclient[412]: DHCPREQUEST for 212.132.74.53 on ens6 to 169.254.0.2 port 67
Jan 25 09:14:06 panel.dreandor.de dhclient[412]: DHCPACK of 212.132.74.53 from 169.254.0.2
Jan 25 09:14:06 panel.dreandor.de dhclient[412]: bound to 212.132.74.53 -- renewal in 287 seconds.
Re: HTTPS Anweisungen bei Subdomain führen zu Connection Refused auf das KH Panel
Das hier ist definitiv falsch.
Sogar doppelt.
https://127.0.0.1/
Localhost gibt es nicht in der SSL Variante.
IP Adressen können kein Zertifikat haben.
Dreandor
Post by Dreandor »
Tobi wrote: Thu 25. Jan 2024, 10:53 Das hier ist definitiv falsch.
Sogar doppelt.
https://127.0.0.1/
  GNU nano 5.4        dreandor_de_mc.dreandor.de_https.conf
SSLProxyEngine On
        SSLProxyVerify none
RewriteEngine on
RewriteRule .* "wss://mc.dreandor.de:8443%{REQUEST_URI}" [P]
ProxyPass / https://mc.dreandor.de:8143/
ProxyPassReverse / https://mc.dreandor.de:8143/
ProxyRequests off
Weiterhin geht Apache2 nicht mehr.
Dreandor
Post by Dreandor »
Wenn ich aber die HTTPS Anweisungen hart in die Vhost Datei schreibe klappt es sogar mit IP Adressen. So bald es über custom_vhosts geladen wird schmiert mir das komplette Panel + Apache2 ab.
Was sagt das Logfile an der Stelle?
BTW:
Dreandor wrote: Thu 25. Jan 2024, 10:13 In HTTP Anweisungen:
RewriteEngine on
Warum?
Das kannst du doch direkt übers Panel einstellen:
Dreandor
Post by Dreandor »
ErrorLog /var/log/apache2/error.log
[Thu Jan 25 13:24:01.908306 2024] [mpm_event:notice] [pid 248148:tid 140133451824448] AH00493: SIGUSR1 received.  Doing graceful restart
[Thu Jan 25 13:24:01.965148 2024] [ssl:warn] [pid 248148:tid 140133451824448] AH01906: webmail:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Thu Jan 25 13:24:01.965173 2024] [ssl:warn] [pid 248148:tid 140133451824448] AH01909: webmail:443:0 server certificate does NOT include an ID which matches the server name
[Thu Jan 25 13:24:01.965296 2024] [ssl:error] [pid 248148:tid 140133451824448] AH02217: ssl_stapling_init_cert: can't retrieve issuer certificate! [subject: emailAddress=info@keyhelp.de,CN=panel.dreandor.de,OU=KeyHelp Control Panel,O=KeyHelp,L=Erfurt,ST=Thuringia,C=DE / issuer: em>
[Thu Jan 25 13:24:01.965305 2024] [ssl:error] [pid 248148:tid 140133451824448] AH02604: Unable to configure certificate webmail:443:0 for stapling
[Thu Jan 25 13:24:01.965772 2024] [:emerg] [pid 248148:tid 140133451824448] AH00020: Configuration Failed, exiting
[Thu Jan 25 13:25:01.619055 2024] [ssl:warn] [pid 249050:tid 140483355684160] AH01906: webmail:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Thu Jan 25 13:25:01.619113 2024] [ssl:warn] [pid 249050:tid 140483355684160] AH01909: webmail:443:0 server certificate does NOT include an ID which matches the server name
[Thu Jan 25 13:25:01.619195 2024] [ssl:error] [pid 249050:tid 140483355684160] AH02217: ssl_stapling_init_cert: can't retrieve issuer certificate! [subject: emailAddress=info@keyhelp.de,CN=panel.dreandor.de,OU=KeyHelp Control Panel,O=KeyHelp,L=Erfurt,ST=Thuringia,C=DE / issuer: em>
[Thu Jan 25 13:25:01.619201 2024] [ssl:error] [pid 249050:tid 140483355684160] AH02604: Unable to configure certificate webmail:443:0 for stapling
AH00016: Configuration Failed
Errorlog /var/log/apache2/keyhelp/error.log
[Wed Jan 24 07:30:34.178724 2024] [ssl:warn] [pid 18487:tid 140492828781888] AH01906: panel.dreandor.de:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Wed Jan 24 07:30:34.178823 2024] [ssl:error] [pid 18487:tid 140492828781888] AH02217: ssl_stapling_init_cert: can't retrieve issuer certificate! [subject: emailAddress=info@keyhelp.de,CN=panel.dreandor.de,OU=KeyHelp Control Panel,O=KeyHelp,L=Erfurt,ST=Thuringia,C=DE / issuer: ema>
[Wed Jan 24 07:30:34.178829 2024] [ssl:error] [pid 18487:tid 140492828781888] AH02604: Unable to configure certificate panel.dreandor.de:443:0 for stapling
[Wed Jan 24 07:30:34.188753 2024] [ssl:warn] [pid 18488:tid 140492828781888] AH01906: panel.dreandor.de:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Wed Jan 24 07:30:34.188843 2024] [ssl:error] [pid 18488:tid 140492828781888] AH02217: ssl_stapling_init_cert: can't retrieve issuer certificate! [subject: emailAddress=info@keyhelp.de,CN=panel.dreandor.de,OU=KeyHelp Control Panel,O=KeyHelp,L=Erfurt,ST=Thuringia,C=DE / issuer: ema>
[Wed Jan 24 07:30:34.188849 2024] [ssl:error] [pid 18488:tid 140492828781888] AH02604: Unable to configure certificate panel.dreandor.de:443:0 for stapling
[Wed Jan 24 07:33:37.728358 2024] [ssl:warn] [pid 697:tid 139641325047104] AH01906: panel.dreandor.de:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Wed Jan 24 07:33:37.728596 2024] [ssl:error] [pid 697:tid 139641325047104] AH02217: ssl_stapling_init_cert: can't retrieve issuer certificate! [subject: emailAddress=info@keyhelp.de,CN=panel.dreandor.de,OU=KeyHelp Control Panel,O=KeyHelp,L=Erfurt,ST=Thuringia,C=DE / issuer: email>
[Wed Jan 24 07:33:37.728604 2024] [ssl:error] [pid 697:tid 139641325047104] AH02604: Unable to configure certificate panel.dreandor.de:443:0 for stapling
[Wed Jan 24 07:33:37.740189 2024] [ssl:warn] [pid 737:tid 139641325047104] AH01906: panel.dreandor.de:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Wed Jan 24 07:33:37.740287 2024] [ssl:error] [pid 737:tid 139641325047104] AH02217: ssl_stapling_init_cert: can't retrieve issuer certificate! [subject: emailAddress=info@keyhelp.de,CN=panel.dreandor.de,OU=KeyHelp Control Panel,O=KeyHelp,L=Erfurt,ST=Thuringia,C=DE / issuer: email>
[Wed Jan 24 07:33:37.740293 2024] [ssl:error] [pid 737:tid 139641325047104] AH02604: Unable to configure certificate panel.dreandor.de:443:0 for stapling
[Wed Jan 24 07:34:27.834051 2024] [authz_core:error] [pid 1675:tid 139640048707328] [client 144.126.202.105:54434] AH01630: client denied by server configuration: /home/keyhelp/www/keyhelp/server-status
[Wed Jan 24 13:59:28.653247 2024] [cgid:error] [pid 36799:tid 140517381179136] [client 185.224.128.191:56396] AH01264: script not found or unable to stat: /usr/lib/cgi-bin/jarrewrite.sh
ich würde wenn die Anweisungen aktiv sind und der Webserver nicht mehr erreichbar ist ein "apache2ctl configtest" ausführen.
Dreandor
Post by Dreandor »
Florian wrote: Thu 25. Jan 2024, 16:03 Hallo,
Scheint alles in Ordnung zu sein
root@panel:~# apache2ctl configtest
Syntax OK
und der Webserver läuft trotzdem nicht bzw. lässt sich nicht starten?
Dreandor
Post by Dreandor »
Florian wrote: Thu 25. Jan 2024, 18:38 Hallo,
Genau. Der Webserver startet trotzdem nicht.
root@panel:~# systemctl status apache2
● apache2.service - The Apache HTTP Server
     Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset: enabled)
     Active: failed (Result: exit-code) since Thu 2024-01-25 18:57:01 CET; 1s ago
    Process: 4297 ExecStart=/usr/sbin/apachectl start (code=exited, status=1/FAILURE)
        CPU: 14ms
Jan 25 18:57:01 panel.dreandor.de systemd[1]: Starting The Apache HTTP Server...
Jan 25 18:57:01 panel.dreandor.de apachectl[4297]: Action 'start' failed.
Jan 25 18:57:01 panel.dreandor.de apachectl[4297]: The Apache error log may have more information.
Jan 25 18:57:01 panel.dreandor.de systemd[1]: apache2.service: Control process exited, code=exited, status=1/FAILURE
Jan 25 18:57:01 panel.dreandor.de systemd[1]: apache2.service: Failed with result 'exit-code'.
Jan 25 18:57:01 panel.dreandor.de systemd[1]: Failed to start The Apache HTTP Server.
und was steht in /var/log/apache2/error.log direkt nach dem Startversuch
Dreandor
Post by Dreandor »
Florian wrote: Thu 25. Jan 2024, 19:01 und was steht in /var/log/apache2/error.log direkt nach dem Startversuch
root@panel:~# systemctl start apache2
Job for apache2.service failed because the control process exited with error code.
See "systemctl status apache2.service" and "journalctl -xe" for details.
[Thu Jan 25 19:02:48.251904 2024] [ssl:warn] [pid 5137:tid 140109540576576] AH01906: webmail:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Thu Jan 25 19:02:48.251967 2024] [ssl:warn] [pid 5137:tid 140109540576576] AH01909: webmail:443:0 server certificate does NOT include an ID which matches the server name
[Thu Jan 25 19:02:48.252046 2024] [ssl:error] [pid 5137:tid 140109540576576] AH02217: ssl_stapling_init_cert: can't retrieve issuer certificate! [subject: emailAddress=info@keyhelp.de,CN=panel.dreandor.de,OU=KeyHelp Control Panel,O=KeyHelp,L=Erfurt,ST=Thuringia,C=DE / issuer: emai>
[Thu Jan 25 19:02:48.252052 2024] [ssl:error] [pid 5137:tid 140109540576576] AH02604: Unable to configure certificate webmail:443:0 for stapling
bitte Logins per PM, muss ich wenn selber gucken.
Dreandor
Post by Dreandor »
Florian wrote: Thu 25. Jan 2024, 19:13 Hallo,
Hab ich dir geschickt.
Dreandor
Re: HTTPS Anweisungen bei Subdomain führen zu Connection Refused auf das KH Panel  [GELÖST]
Post by Dreandor »
Dank der Hilfe von Florian geht es wieder.
Lag an
Wenn ich die beiden entferne dann geht es auch wieder.
