KeyHelp has been updated to version 24.0.
Natig
Post by Natig »
Hello, how can I remove this from the server?
https://zaka.biz/files/img/server-note.png
This server is powered by KeyHelp!
* Control panel access:
https://name.server
https://ip-adress
* CLI utilities:
# keyhelp
# keyhelp-toolbox
Re: KeyHelp has been updated to version 24.0.
It is not clear, what are you trying to remove. The whole Message of the Day? Only "powered by KeyHelp"? The IPs and hostnames?
Open this file
/etc/update-motd.d/80-keyhelp
Use the following parameters (at the top of the script) to switch off various parts of the message of the day, simply by setting them to "0" instead of "1".
show_powered_by_keyhelp=1
show_login_hostname=1
show_login_ipv4=1
show_login_ipv6=1
Natig
Post by Natig »
I dropped that too
show_login_hostname=0
show_login_ipv4=0
show_login_ipv6=0
now shows it https://zaka.biz/files/img/server-note-0.png
Error 403!
You can attach images to this board.
a) No spammy site with ads is needed.
b) If someone reads this thread in a year or so, it is still meaningful.
And, besides, for plain text you can use the code tags: </>
Linux keyhelp.lab.24unix.net 6.1.0-13-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.55-1 (2023-09-29) x86_64
      https://keyhelp.lab.24unix.net
      https://192.168.99.66
      https://[2a03:7847:2252:180:5054:ff:fe6c:13d1]
  * Login data:
      /root/keyhelp_login_data_2022-07-19_13-10-17
  * CLI utilities:
      # keyhelp
      # keyhelp-toolbox
Last login: Mon Feb 12 12:03:31 2024 from 2a03:7847:2252:180:a00:27ff:fed1:cb53
Florian wrote: Mon 12. Feb 2024, 19:23Error 403!
For me also the first spammy site worked.
Natig
Post by Natig »
now shows it
  * Login data:
      /root/keyhelp_login_data_*******
  * CLI utilities:
      # keyhelp
      # keyhelp-toolbox
That is a good solution :-)
So, are you happy with that, or do you need further adaption?
Alex asked in his first reply what you want to achieve.
Natig
Post by Natig »
I want to delete it all
  * Login data:
  * CLI utilities:
      # keyhelp
      # keyhelp-toolbox
Natig wrote: Mon 12. Feb 2024, 19:48 I want to delete it all
You are very sparse with words :-)
So, you want to disable the whole modt?
SSH? For one user?
touch $HOME/.hushlogin
Why?
Jolinar wrote: Mon 12. Feb 2024, 19:56
Why?
Why not? :-)
When I'm logged in, I know where I am.
If I need IP:
ip a
Login data:
ls -lr
And after a while you know which cli utils are available :-)
So, the motd is nice, but superfluent …
Edit: And If I login as a regular user:
  * Login data:
  * CLI utilities:
      # keyhelp
      # keyhelp-toolbox
Last login: Mon Feb 12 20:04:40 2024 from 2a03:7847:2252:180:a00:27ff:fed1:cb53
I have no access to /root<whatsoever>
So the use is quite limited.
Natig
Post by Natig »
I don't want to see this every time in ssh
Natig wrote: Mon 12. Feb 2024, 20:04 I don't want to see this every time in ssh
Did the .hushlogin work?
Natig
Post by Natig »
Thank you very much it worked.
