Restore funktioniert nicht  [GELÖST]
byte3000
Post by byte3000 »
Ja
(z.B. Ubuntu 20.04)
Debian 12.5 (64-bit)
(z.B. 22.0 - Build 2366)
24.0 (Build 3220)
Das Restore bleibt hängen oder bricht ab
Restore sollte ordnungsgemäß durchgeführt werden.
Restore bleibt hängen oder bricht ab.
Restore auf einem anderen Server bleibt auch hängen oder bricht ab.
Failed to restore backup: Remove(<lock/c54a8901c5>) returned error, retrying after 1.979218234s: blob not removed, server response: 500 Internal Server Error (500)
rclone: 2024/02/24 16:49:54 ERROR : locks/c54a8901c56d92c306fc99633e3e4d3f8ed2c0ae558652afd291d1b2c5a6e11f: Delete request remove error: write tcp 2.58.54.78:53506->185.87.21.95:21: write: broken pipe
Remove(<lock/c54a8901c5>) returned error, retrying after 1.362013358s: blob not removed, server response: 500 Internal Server Error (500)
rclone: 2024/02/24 16:49:56 ERROR : locks/c54a8901c56d92c306fc99633e3e4d3f8ed2c0ae558652afd291d1b2c5a6e11f: Delete request remove error: write tcp 2.58.54.78:53530->185.87.21.95:21: write: broken pipe
Remove(<lock/c54a8901c5>) returned error, retrying after 5.361602699s: blob not removed, server response: 500 Internal Server Error (500)
rclone: 2024/02/24 16:50:01 ERROR : locks/c54a8901c56d92c306fc99633e3e4d3f8ed2c0ae558652afd291d1b2c5a6e11f: Delete request remove error: write tcp 2.58.54.78:53522->185.87.21.95:21: write: broken pipe
Remove(<lock/c54a8901c5>) returned error, retrying after 4.970997582s: blob not removed, server response: 500 Internal Server Error (500)
rclone: 2024/02/24 16:50:06 ERROR : locks/c54a8901c56d92c306fc99633e3e4d3f8ed2c0ae558652afd291d1b2c5a6e11f: Delete request remove error: write tcp 2.58.54.78:53534->185.87.21.95:21: write: broken pipe
Remove(<lock/c54a8901c5>) returned error, retrying after 11.687103066s: blob not removed, server response: 500 Internal Server Error (500)
rclone: 2024/02/24 16:50:18 ERROR : locks/c54a8901c56d92c306fc99633e3e4d3f8ed2c0ae558652afd291d1b2c5a6e11f: Delete request remove error: write tcp 2.58.54.78:53510->185.87.21.95:21: write: broken pipe
Remove(<lock/c54a8901c5>) returned error, retrying after 15.469280824s: blob not removed, server response: 500 Internal Server Error (500)
rclone: 2024/02/24 16:50:33 ERROR : locks/c54a8901c56d92c306fc99633e3e4d3f8ed2c0ae558652afd291d1b2c5a6e11f: Delete request remove error: write tcp 2.58.54.78:53506->185.87.21.95:21: write: broken pipe
Remove(<lock/c54a8901c5>) returned error, retrying after 14.00157549s: blob not removed, server response: 500 Internal Server Error (500)
rclone: 2024/02/24 16:50:47 ERROR : locks/c54a8901c56d92c306fc99633e3e4d3f8ed2c0ae558652afd291d1b2c5a6e11f: Delete request remove error: write tcp 2.58.54.78:53530->185.87.21.95:21: write: broken pipe
Fatal: There were 2 errors
[Mod-Edit]
CODE-Tags eingefügt.
Reason: Mod-Edit
Re: Restore funktioniert nicht  [GELÖST]
sieht danach aus, das FTP bzw. der Remote-Server dafür verantwortlich ist.
Stelle einmal auf SFTP um und versuche es erneut.
byte3000
Post by byte3000 »
Hab auf SFTP umgestellt und bis jetzt funktioniert es. Perfekt, vielen herzlichen Dank!!! :D :D :D
Henning
Post by Henning »
Seitdem ich auf SFTP umgestellt habe, laufen die Sicherungen wieder ordnungsgemäß durch.
Freundliche Grüße von Henning
