Two Factor Auth - Where can I download my secret keys?  [SOLVED]
MDylan
Post by MDylan »
As administrator, I want to use Two factor authentication.
I can set it up successfully (using google authenticator app), but I not find, where can I download my secret keys?
The panel message is:
Attention! Make sure to have a backup of your secret key in case you lose access to your device.
I think maybe it's missing from this area? :?:
Re: Two Factor Auth - Where can I download my secret keys?  [SOLVED]
This is your key, on the left is your key is QR code form, on the right in plain text.
As a note: You as a admin are always able to remove the two-factor-auth (or the ones of your clients) in case you lost your auth-device using the CLI tool "keyhelp-toolbox".
MDylan
Post by MDylan »
Ah ok sorry. I searched it after I have set the 2FA... :?
I would not bother so much about it yet. Like I said, in case you loose your device, just log in via SSH - call "keyhelp-toolbox" and pick the corresponding option to reset 2FA for your account.
