2nd domain to the existing user does not load
Chalipa
Post by Chalipa »
Debian 12.5 (64-bit)
24.0 (Build 3220)
I have added a domain i.e domain.com with the existing user and pointed it to www/domain2.com/ but now it's not loading. Firefox and safari are saying
The page isn’t redirecting properly
The first domain in the user is working fine which is pointed to www/domain.com/
Expected result
website should be loading
Actual result
website is not loading
Steps to reproduce
Additional information
Re: 2nd domain to the existing user does not load
"The page isn’t redirecting properly" - This reads, as there is still an other server responsible for the domain.
Have you checked your DNS settings?
Is domain2.com resolving correctly to the KeyHelp server?
Have you waited 1 minute until all configurations have been updated?
Chalipa
Post by Chalipa »
Alexander wrote: Tue 2. Apr 2024, 09:08 "The page isn’t redirecting properly" - This reads, as there is still an other server responsible for the domain.
DNS for both domains are hosted with cloudflare and they are correctly being pointed to the server, and strangely domain1.com is working and domain2.com is not.
Yes, I have waited several minutes for configurations to be updated, but still same result.
what is the extact error you get in the browser?
Chalipa
Post by Chalipa »
Florian wrote: Tue 2. Apr 2024, 15:45 Hallo,
Firefox:
https://jmp.sh/ZDxVFu4w
Safari:
https://jmp.sh/UXgOWcxK
I can provide you with keyadmin login details (if needed) to check.
you have got a redirect loop, eg from http -> https -> http -> https and so on that never comes to an end. Use browser plugins lke "redirect path" or "Link redirect trace" to inspect the redirects on your website.
Chalipa
Post by Chalipa »
I have that not enabled, and i used the plugin it didn't find anything
https://jmp.sh/tHCVqeJ5
Sorry this is not helpful, it only shows the folders of your domain in Keyhelp.
I am talking about redirects. This is a common problem when using Cloudflare
PS: And please insert the screenshots in the text and not via an external URL
