24.1 error  [SOLVED]
kivamp
24.1 error
Post by kivamp »
Keyhelp 24.1
Debian 12
Can't save domain changes.
PHP Fatal error: Uncaught TypeError: trim(): Argument #1 ($string) must be of type string, array given in /home/keyhelp/www/keyhelp/core/SystemConfig/Webserver/PhpFpmPoolConfig.php:349
Re: 24.1 error
Why you did not fill out the required error reporting template?
Especially this question is important: Steps to reproduce
The error reporting template is there for a reason, so that we don't have to ask for everything problem related.
Please answer at least this question and show the content of all fields within the KeyHelp UI you have filled out to reproduce this.
STOP - Please read the next lines carefully!
1) Please fill out the post template below completely!
2) The members of this forum provide their valuable time to help! In return, please provide as much information as possible and be specific in your error description. Posts that show little initiative will probably not get good responses!
You may remove this top portion of the post template.
However, do not remove the following post template under any circumstances.
(Problems not related to KeyHelp belong in the Offtopic forum)
(e.g. Ubuntu 20.04)
(e.g. none, OpenVZ, KVM, XEN, etc.)
(e.g. 22.0 - Build 2366)
Expected result
Actual result
Steps to reproduce
Additional information
(e.g. recent changes to the server, excerpts from log files (/var/log/*, /var/log/keyhelp/php-error.log, etc.))
kivamp
Re: 24.1 error
Post by kivamp »
It appeared after updating to 24.1
Debian 12.5
none
24.1 (Build 3285)
Not save domain after edit it
Expected result
Domain saved and its status 1
Actual result
Domain status - 4
Steps to reproduce
Domain edit -> save
Important warning: two (or more) php versions must be installed.
[11-Jun-2024 09:18:01 Europe/Chisinau] PHP Fatal error: Uncaught TypeError: trim(): Argument #1 ($string) must be of type string, array given in /home/keyhelp/www/keyhelp/core/SystemConfig/Webserver/PhpFpmPoolConfig.php:349
Stack trace:
#0 /home/keyhelp/www/keyhelp/core/SystemConfig/Webserver/PhpFpmPoolConfig.php(349): trim()
#1 /home/keyhelp/www/keyhelp/core/SystemConfig/Webserver/PhpFpmPoolConfig.php(254): PhpFpmPoolConfig->generate()
#2 /home/keyhelp/www/keyhelp/core/pending/Apache.php(1189): PhpFpmPoolConfig->save()
#3 /home/keyhelp/www/keyhelp/core/pending/Apache.php(905): Apache->applyUserConfigs()
#4 /home/keyhelp/www/keyhelp/cronjob/jobs/update.php(2300): Apache->applyAllConfigChanges()
#5 /home/keyhelp/www/keyhelp/cronjob/mastercronjob.php(464): unknown()
#6 {main}
thrown in /home/keyhelp/www/keyhelp/core/SystemConfig/Webserver/PhpFpmPoolConfig.php on line 349
Re: 24.1 error  [SOLVED]
Unfortunately you have not read this:
Alexander wrote:Please answer at least this question and show the content of all fields within the KeyHelp UI you have filled out to reproduce this.
Please show the exact content of the 'Additional PHP directives' fields of the corresponding client.
Re: 24.1 error
Did you change the operating system PHP version manually?
