How to disable OpenSPF on Posfix level ?  [SOLVED]
amarc
Post by amarc »
Rspam itself have SPF check and this OpenSPF is more wrong than right (too much false possitives). I need to disable this check on Postfix level, how can I do this ?
Thank you
Re: How to disable OpenSPF on Posfix level ?
main.cf
check_policy_service unix:private/policy
master.cf
# Python SPF Policy
policy  unix  -       n       n       -       -       spawn
        user=nobody argv=/usr/bin/policyd-spf /etc/postfix-policyd-spf-python/policyd-spf.conf
Re: How to disable OpenSPF on Posfix level ?  [SOLVED]
Just a note for the upcoming update:
On modern systems with KeyHelp and Rspamd (Debian 12+, Ubuntu 24.04+), postfix-policyd-spf-python will be removed and Rspamd will handle the SPF checking.
