I set relayhost but not success.  [SOLVED]
akong77
Post by akong77 »
I remember keyhelp can edit postfix config file.But I install latest keyhelp.I edit main.cf file and add relayhost setup.But it's not relay to my setup address.It's always send mail direct.How to check it?
Re: I set relayhost but not success.  [SOLVED]
either disable SRS in configuration -> E-Mail-Server or check this thread:
viewtopic.php?p=52057#p52057
akong77
Post by akong77 »
Yes,It's fix done.Thanks a lot
