New IP added to server but it does not shows in KeyHelp
Chalipa
Post by Chalipa »
I have had a server with one IP and recently I ordered a second IP, but it does not show the new IP under
Settings / Configuration / IP Addresses
It just shows the old IP, is there any file that I need to edit?
I don't want to reinstall everything (Debian etc..) from scratch.
Thanks,
otto58
Re: New IP added to server but it does not shows in KeyHelp
Post by otto58 »
Does ifconfig show the new IP?
you have to configure the IP manually on your server. Then it will be shown in Keyhelp
