Errors bei frischer Neuinstallation von KeyHelp auf jungfreulichen Server  [GELÖST]
Post by Fezzi »
Ich weis nicht
Debian 12.8 (64-bit) minimal System NetCup VPS vorinstalliert und jungfreulich
24.2 (Build 3326)
Ihre KeyHelp-Installation funktioniert möglicherweise nicht wie erwartet, solange die Ursachen für diese Fehler nicht behoben sind.
Bei der Installation der folgenden Module traten Probleme auf: AWStats, Fail2ban, Logrotate
Dass die drei Module installiert werden
Errors bei der Installation
Keine
Hier der Auszug aus dem Installations Protokoll
  AWStats
  exec  | apt-get install -y awstats
          E: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 27392 (apt-get)
          E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), is another process using it?
  [SKIPPED DUE PREVIOUS ERRORS] exec  | rm -f /etc/cron.d/awstats
  [SKIPPED DUE PREVIOUS ERRORS] exec  | rm -f /etc/awstats/awstats.conf
  Fail2ban
  exec  | apt-get install -y fail2ban python3-pyinotify python3-systemd
  [SKIPPED DUE PREVIOUS ERRORS] exec  | systemctl enable fail2ban
  [SKIPPED DUE PREVIOUS ERRORS] files | fail2ban/jail.d/keyhelp.local => /etc/fail2ban/jail.d/keyhelp.local
  [SKIPPED DUE PREVIOUS ERRORS] files | fail2ban/filter.d/keyhelp-mariadb.conf => /etc/fail2ban/filter.d/keyhelp-mariadb.conf
  [SKIPPED DUE PREVIOUS ERRORS] files | fail2ban/filter.d/keyhelp-phpmyadmin.conf => /etc/fail2ban/filter.d/keyhelp-phpmyadmin.conf
  [SKIPPED DUE PREVIOUS ERRORS] files | fail2ban/filter.d/keyhelp-snappymail.conf => /etc/fail2ban/filter.d/keyhelp-snappymail.conf
  [SKIPPED DUE PREVIOUS ERRORS] files | fail2ban/filter.d/keyhelp-bad-bots.conf => /etc/fail2ban/filter.d/keyhelp-bad-bots.conf
  [SKIPPED DUE PREVIOUS ERRORS] exec  | chown keyhelp:keyhelp /etc/fail2ban/jail.d/keyhelp.local
  [SKIPPED DUE PREVIOUS ERRORS] exec  | service fail2ban restart
  [SKIPPED DUE PREVIOUS ERRORS] files | fail2ban/filter.d/fixes/1.1.0-apache-common.conf => /etc/fail2ban/filter.d/apache-common.conf
  [SKIPPED DUE PREVIOUS ERRORS] files | fail2ban/filter.d/fixes/1.1.0-postfix.conf => /etc/fail2ban/filter.d/postfix.conf
  Logrotate
  exec  | apt-get install -y logrotate
  [SKIPPED DUE PREVIOUS ERRORS] files | logrotate/keyhelp => /etc/logrotate.d/keyhelp
  [SKIPPED DUE PREVIOUS ERRORS] files | logrotate/logrotate.timer => /lib/systemd/system/logrotate.timer
  [SKIPPED DUE PREVIOUS ERRORS] files | logrotate/logrotate.service => /lib/systemd/system/logrotate.service
  [SKIPPED DUE PREVIOUS ERRORS] exec  | systemctl daemon-reload
Danke schon mal in Voraus fuer Eure Hilfe wie ich hier weiterkomme.
Re: Errors bei frischer Neuinstallation von KeyHelp auf jungfreulichen Server
wie man sieht ist dpkg gelockt durch einen anderen Prozess.
Ich würde der Einfachheit halber empfehlen den Server plus Keyhelp nochmal neu zu installieren.
Post by Fezzi »
Hallo Florian,
danke fuer die schnelle Rueckmeldung... das werde ich mal machen und melde mich wieder...
Hier ist es schon ein wenig spaeter... wird also erst morgen geschehen...
Danke nochmal und ich sage dann Bescheid ob oder ob es nicht geklappt hat...
Normalerweise lässt es der Pre-Installer garnicht zu, das die installation gestartet werden kann, sofern z.B. unattended-upgr oder dergleichen läuft. Kann natürlich sein das der sich irgendwo dazwischen gedrängt hat, oder zeitgleich noch diverse andere apt-Befehle abgesetzt wurden.
Hier die Lösung:
1) Server zurück setzten
2) Aktuelle Uhrzeit einstellen (das sollte unattended.upgr triggern, wobei das nur für Ubuntu relevant wäre)
  date -s "$(wget -qSO- --max-redirect=0 google.com 2>&1 | grep Date: | cut -d' ' -f5-8)Z"
3) Jetzt entweder warten und nach 30 Minuten die Installation nochmal versuchen.
Oder wenn du selbst auf nummer sicher gehen willst.
4) Schauen ob noch irgendwo ein lock besteht:
lsof /var/lib/dpkg/lock ;
lsof /var/lib/apt/lists/lock ;
lsof /var/lib/dpkg/lock-frontend ;
Wenn nein, Installation starten.
Post by Fezzi »
Hallo Alex,
danke fuer die zusaetzlichen Infos.... ich check das mal Morgen...
Das Ding ist ja zum Testen... :)
WIll mir damit mal RSpam naeher anschauen und auch mittelfristig weg von Ubuntu und den Produktiv Server auf Debian umstellen...
Aber jetzt erst mal testen...
Danke nochmal and Euch Beide (Florian & ALex) Eure Reaktionszeiten sind und Hilfestellungen sind schwer zu schlagen... ;)
Re: Errors bei frischer Neuinstallation von KeyHelp auf jungfreulichen Server  [GELÖST]
Post by Fezzi »
Ok, Entwarnung... nach einer Neuinstallation von Debian hat alles so funktioniert wie es soll...
Danke nochmals an Alex und Florian fuer die schnelle Rueckmeldung von Gestern.
PS: Das Thema kann als Geloest markiert werden.
