video been played instead download .mkv
i added this on the web panel config bottom, there is not a lot of options
<IfModule mod_mime.c>
AddType video/x-matroska .mkv
</IfModule>
Re: video been played instead download .mkv
Convert the mkv video to mp4 format.
i think those are in .mkv because the size and quality. i will do some tests to check if it works.
Instead, they will just download the file.
If file size is important, you are better off using WebM.
thanks for your response
