Warning: MySQL - Connection Error: No such file or directory
marcus198514
habe ein Problem. Wenn ich Keyhelp aufrufe bekomme ich die Meldung. Kann da jemand Helfen ?
wenn ich folgendes mache bekomme ich die Ausgabe :
# keyhelp-toolbox
Warning: MySQL - Connection Error: No such file or directory in /home/keyhelp/www/keyhelp/core/pending/DBConnectio n.php on line 338
Fatal error: Uncaught Error: Call to a member function query() on null in /home/keyhelp/www/keyhelp/core/pending/D BConnection.php:114
Stack trace:
#0 /home/keyhelp/www/keyhelp/core/pending/DBConnection.php(65): DBConnection->connect()
#1 /home/keyhelp/www/keyhelp/core/pending/DBConnection.php(374): DBConnection->__construct()
#2 /home/keyhelp/www/keyhelp/bin/keyhelp_toolbox.php(32): DBConnection::getConnection()
#3 {main}
thrown in /home/keyhelp/www/keyhelp/core/pending/DBConnection.php on line 114
Speicher war voll ! Habe dann einiges gelöscht.
# df -h
Filesystem Size Used Avail Use% Mounted on
tmpfs 13G 1.2M 13G 1% /run
/dev/md2 3.5T 2.8T 490G 86% /
tmpfs 63G 0 63G 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
/dev/md1 989M 183M 756M 20% /boot
tmpfs 13G 0 13G 0% /run/user/0
# sudo systemctl restart mariadb.service
Job for mariadb.service failed because the control process exited with error code.
See "systemctl status mariadb.service" and "journalctl -xeu mariadb.service" for details.
Tab stops: eu mariadb.service
Jan 06 09:30:00 xxxxxxxxxx mariadbd[2521]: 2025-01-06 9:30:00 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Pl>
Jan 06 09:30:00 xxxxxxxxxx mariadbd[2521]: 2025-01-06 9:30:00 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
Jan 06 09:30:00 xxxxxxxxxx mariadbd[2521]: 2025-01-06 9:30:00 0 [Note] InnoDB: 10.6.18 started; log sequence number 1317611616618; transaction id 10524000>
Jan 06 09:30:00 xxxxxxxxxx mariadbd[2521]: 2025-01-06 9:30:00 0 [Note] Plugin 'FEEDBACK' is disabled.
Jan 06 09:30:00 xxxxxxxxxx mariadbd[2521]: 2025-01-06 9:30:00 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
Jan 06 09:30:00 xxxxxxxxxx mariadbd[2521]: 2025-01-06 9:30:00 0 [ERROR] Could not open mysql.plugin table: "Unknown storage engine 'Aria'". Some plugins m>
Jan 06 09:30:00 xxxxxxxxxx mariadbd[2521]: 2025-01-06 9:30:00 0 [ERROR] Failed to initialize plugins.
Jan 06 09:30:00 xxxxxxxxxx mariadbd[2521]: 2025-01-06 9:30:00 0 [ERROR] Aborting
Jan 06 09:30:01 xxxxxxxxxx systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE
░░ Subject: Unit process exited
░░ Defined-By: systemd
░░ Support: http://www.ubuntu.com/support
░░ An ExecStart= process belonging to unit mariadb.service has exited.
░░ The process' exit code is 'exited' and its exit status is 1.
Jan 06 09:30:01 xxxxxxxxxx systemd[1]: mariadb.service: Failed with result 'exit-code'.
░░ Subject: Unit failed
Vielen Dank für die Hilfe
Re: Warning: MySQL - Connection Error: No such file or directory
Schaff Platz auf der Kiste, dann läuft auch wieder alles...marcus198514 wrote: ↑Mon 6. Jan 2025, 09:34 tmpfs 13G 1.2M 13G 1% /run
marcus198514
der Platz ist nicht das Problem, da / nur zu 86 % belegt ist.
Der Fehler ist:
Dazu findet man einige Ansatzpunkte via Recherche.[ERROR] Could not open mysql.plugin table: "Unknown storage engine 'Aria'". Some plugins m>
marcus198514
gibt es jemand der Helfen kann ? Habe den Keyhelp Service bereits per Chat geschrieben jedoch kommt da keine Antwort.
du hast mich per PM angeschrieben. Das ist kein Chat!
Ich habe erstmal unsere Kunden die Support benötigen und dann schaue ich es mir ggf an, wobei meine Motivation bei solchen Aussagen nicht steigt
marcus198514
Zählt man mit einer Pro Lizenz nicht als Kunde ?
Ich habe auf der Webseite den Chat geöffnet und dort auch geschrieben
Ebenfalls auch dich per PN.
Also alles gut
woher soll ich wissen, dass du eine Lizenz hast?
Mit einer Lizenz kannst du ein kostenloses Ticket aufmachen bei uns, obwohl dieses Problem nichts mit Keyhelp zu tun hat.
Lösung:
mv /var/lib/mysql/aria_log_control /var/lib/mysql/aria_log_control.orig
systemctl start mariadb.serviceFlorian Cheno
