MySQL - Query Error: The table 'event_logs' is full
picaditto
Post by picaditto »
Hello to all,
When i try to login i get these error "MySQL - Query Error: The table 'event_logs' is full"
Try to restart and now no user UI
Any help please.
Re: MySQL - Query Error: The table 'event_logs' is full
Probably you ran out of Webspace.
picaditto
Post by picaditto »
Thanks for the reply, i dont think is that.
root@hera ~ # df -h
Filesystem Size Used Avail Use% Mounted on
tmpfs 6.3G 2.8M 6.3G 1% /run
/dev/md2 906G 11G 849G 2% /
tmpfs 32G 64K 32G 1% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
/dev/md1 989M 186M 753M 20% /boot
tmpfs 6.3G 12K 6.3G 1% /run/user/0
more information about your database setup are needed.
Have you changed anything regarding your database setup, changed config values etc.?
How many records does the event_log table have?
Have you turned on "KeyHelp Admin area -> System status -> Event logs -> Options -> Do not delete records" (in general, what are your settings configurated there)?
Check your innoDB table limits (https://dev.mysql.com/doc/refman/8.4/en ... limit.html)
Are there any related errors here /var/log/keyhelp/php-error.log?
You can truncate the `keyhelp`.`event_logs` table without problems, this way you can likely access KeyHelp again.
